Flex Innovations has a new EDF Jet out called the FLEXJET PRO 90MM EDF ARF+. They took the awesome FlexJet Super PNP and upsized it a bit with new composite construction. It was designed by multi-time Top Gun Champion, David Ribbe with aerodynamic collaboration from F3A World Champion Quique Somenzini. The FlexJet Pro’s fuselage utilizes a painted fiberglass shell with plywood reinforcement in key areas to maximize aerodynamic performance, while keeping the airframe clean, rigid, and lightweight. The wings and horizontal stabilizers are constructed from balsa and plywood and covered in a high-visibility, military-inspired color scheme.
Thanks to expertly tuned inlet lips and full ducting, the FlexJet Pro provides efficient thrust over a wide range of speed, while not requiring unsightly and performance reducing cheater holes to mask inferior engineering. All-moving “flying stabs” give excellent pitch control at all speeds and can be even used as “tailerons” to aid in roll authority at slower speeds.
The FlexJet Pro’s robust, CNC-machined aluminum trailing link struts take the drama out of landings on all runway surfaces including grass or other rough fields. The main landing gear are located in the fuselage near the CG to provide easy ground handling, take-off rotation and the famous “wheelie” landings that the FlexJet is known for. The fuselage-mounted main gear allows for multiple transportation and storage options without requiring the wings to be installed.
The FlexJet Pro is a high-performance EDF Jet providing “turbine-like” performance in a smaller and more convenient EDF package. If you’re looking for that next step into larger and higher performance jets, the FlexJet Pro is your next stop on that jet-jockey journey!
The FlexJet Pro 90MM EDF ARF+ is due out this summer with a price of $699.99.
Flex Innovations FlexJet Pro - Teaser (0 min 30 sec) |
Thread Tools |
yes we know and its a winner
needs very little runway due to the power output and landing might be carrier style in long grass
“ Expertly engineered inlet lips and full ducting provides incredible thrust while remaining clean and efficient” |
Wrong thread
Thread Tools | |
Similar Threads | |||||
Discussion | New FLEXJET PRO 90MM EDF ARF+ | Aussie1au | Electric Ducted Fan Jet Talk | 586 | Apr 06, 2021 04:57 PM |
Cool | New 90mm FlexJet from Flexinnovations | Robert Belluomini | Foamy EDFs | 1895 | Apr 04, 2021 12:55 PM |
New Product | Flexjet pro 90mm edf arf+ | Go4it | Electric Ducted Fan Jet Talk | 1 | Mar 05, 2020 03:59 PM |
Discussion | Where are those "not ARF" kits, for powerfull 90mm edf | Hoeby | Electric Ducted Fan Jet Talk | 6 | Apr 25, 2017 09:16 PM |
