Mar 05, 2020, 09:43 AM
Go4it's Avatar
New Product
Flexjet pro 90mm edf arf+
FLEXJET PRO 90MM EDF ARF+
$670 jet to finish $1,100 +receiver and transmitter
Features:
Professionally painted fiberglass fuselage and wood-built wings for a clean, pro-class performance
Expertly engineered inlet lips and full ducting provides incredible thrust while remaining clean and efficient
Modern aerodynamics such as leading-edge root extensions (LERX’s) and a ball bearing supported all-moving stabilizers for high performance and easy handling, even at lower airspeeds
The included and installed retracts, gear door servos and nose gear servo save hours of build and setup time and are also designed to work with high voltage power systems (8.4V)
Included and installed CNC-machined trailing link struts provide excellent ground handling, even on grass or rough fields
Large battery compartment with easy-access top hatch provides great access to the flight battery and other key electrical components
(4) DS16HV gear door servos included and installed
Ball-bearing supported and mass-balanced, all-moving stabilators
Custom painted and covered in a high-visibility, military-inspired trim scheme
RECOMMENDED COMPLETION ITEMS:
8+ Channel Computer Transmitter
Futaba T6K
8+ Channel Receiver
Spektrum AR8010T (For Spektrum users)
Futaba R7008SB (For Futaba FASSTest users)
Futaba R3006SB (For Futaba T-FHSS users with Aura AFCS)
Futaba R6208SB (For Futaba FASST users)
90mm EDF Unit and Motor
JP Hobby/Flex Innovations 90mm 8S EDF Unit and Motor
120A High-Voltage (8S Capable) ESC
V-Good 120A 8S ESC
(5) 90+ oz. in. Mini Servos
Potenza DS11106HV Servos
Receiver Battery
Potenza 2S 2000mAh 25C Li-Po
Flight Battery
Potenza 8S 6200mAh 40C Li-Po
OPTIONAL UPGRADES AND ACCESSORIES:
3-Axis Gyro
Aura 8 AFCS
Wheel Brakes
Flex Innovations Wheel Brakes, Wheels and Brake Controller (High-Voltage Compatible) by JP Hobby
Mar 05, 2020, 03:59 PM
I am very interested in this. I have never been a huge fan of the foam jets, but this composite version is looking pretty good. I will be interested to see what actual flight times are on this....
Discussion New FLEXJET PRO 90MM EDF ARF+ Aussie1au Electric Ducted Fan Jet Talk 586 Apr 06, 2021 04:57 PM
Cool New 90mm FlexJet from Flexinnovations Robert Belluomini Foamy EDFs 1895 Apr 04, 2021 12:55 PM
Discussion What EDF ARF or KIT Jet for 90mm @8s Piotrek_SGM Electric Ducted Fan Jet Talk 21 Jun 15, 2018 01:17 AM
Discussion Where are those "not ARF" kits, for powerfull 90mm edf Hoeby Electric Ducted Fan Jet Talk 6 Apr 25, 2017 09:16 PM
