Mar 04, 2020, 07:33 AM
Build Log
Super Bandit foamy with Kolibrie T30 turbine
Hi friends, here are some pictures of a new build:
I have been inspired by this design but have done some design changes to suit my building technology and personal taste.
https://www.rcgroups.com/forums/show...andit-Park-Jet
Thank you for your inspiration and hard work, Steve .
My build is 1800 mm / 70.9 inches long and will have a span of 1600 mm/63 inches.
The engine to be used is a Kollibrie T30 (3 kg / 3,0kp).
I build in thin foam sheets (5/10 mm/ 0,19/0,69 inch), with reinforcement of balsa / ply laminate and fiberglass in strategic places.
I'm aiming for a starting weight of about 4000 gr / 8.8 lb so this is going to be a very light and slow flying plane.
In the first picture we see the inner frame structure which will hold the front landing gear, tank, wing and engine.
(Not much foam here but it will come :-)
In the second picture: Beginning of the wing:
5 mm foam sheet.
// Mats W
Mar 15, 2020, 11:54 AM
Hi, work in pregress ower here:
Testing/ adjusting conection between wing and superstructure.
Then startaed om fin and stabilazer. Time to add some foam to this Project now:
I glue with PU-Glue.
It is important to put strong tape ower the joints, otherwise the glue will come out and make ugly marks.
The PU-Glue is fantstic to work with, i makes very strong joints.
Takes time to cure but its Worth it.
// Mats W
Mar 15, 2020, 07:40 PM
Park Jet Guru
jetset44's Avatar
Looks like a fun project! I'm glad to be an inspiration and look forward to seeing how this turns out!
Steve
Mar 16, 2020, 07:01 PM
Retired CAD guy
birdofplay's Avatar
So ...
errr , Ummm ...
Where is the Foam ???
Mar 17, 2020, 10:46 AM
Originally Posted by birdofplay
So ...
errr , Ummm ...
See my first post and recent pic`s.
This plane is built from inside and out.
// Mats W
Mar 18, 2020, 02:18 PM
Time to dress the fuselage in foam now:
Starting with a "nosejobb".
Testmount of landing-gear:
I miscalculated the high of the wheels so i had to remove a part of the longerong .
Vill replace it wit other material later.
Allso added all the formers in the wing.
Small steps every day :-)
// Mats W
Mar 20, 2020, 07:52 AM
The thing is standing on its legs:
And one cant even see what its going to look like yet?? :-)
(But the headline giveas a clue).
A bit strange way of doing it but i think it will work fine?
Fin an stab ready for final trimming and cover:
// Mats W
Mar 20, 2020, 08:07 AM
Learning to make
The wing looks AWESOME!
Mar 20, 2020, 08:12 AM
Thankyou fossil 1999, i Think that it will do the jobb?
// Mats W
Mar 20, 2020, 08:34 AM
Learning to make
The main spar looks tall enough.
Mar 25, 2020, 11:40 AM
The "thing" is tranforming to a foamie:
// M
New Product KingTech T30 mini Turbine 3.0 kg velyter Jet Turbines 1057 Nov 18, 2019 02:17 PM
Discussion Need help on Kolibri T30 ECU dididodoT Jet Turbines 4 Nov 26, 2018 03:15 PM
Question Difference between the Lambert T30 and T35 turbines? luckyflyer Jet Turbines 45 Sep 11, 2018 11:33 PM
Discussion Turbine Indoor Jet (Depron + Kolibri) Lownoise Jet Turbines 8 Oct 17, 2016 05:31 AM
Discussion Lambert Kolibri T30 littlepiston Jet Turbines 16 Jul 03, 2013 03:13 PM
