This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Mar 02, 2020, 04:07 PM
Mini-Review
Reptile Cloud 149 CineWhoop
Reptile CLOUD-149 is a 3 inch Mega CineWhoop. For less money you can get a solid quad for cinematic video filming with e.g. a GoPro camera.
Get the Reptile CLOUD-149 from [CZ] EU warehouse with the coupon: aFfBg10 - https://www.banggood.com/custlink/3Dvvl7sWcf
Coupon2: BGRE149
Video 1 - Reptile Cloud 149 CineWhoop good and less $130 (EN subtitles)
Reptile Cloud 149 CineWhoop gut und günstig (4 min 36 sec)
The PNP 3 inch CyneWhoop has 20A ESC's, F4 FC, 1407 4000KV motors, 25-500mW VTX video transmitter.
In delivery, the Reptile CLOUD-149 is ready to fly without a receiver (PNP) with a GoPro 6-7 holder.
Fast 1408 4000KV motors. Run very well with 4S and even fly well with 3S.
Total weight with GoPro Session 5 and a 4S 1550mAh battery 476 grams
Empty weight 214 grams
Video transmitter 25to 500mW
The FPV camera has a 16: 9 aspect ratio. Ok, but not good enough for me. I would prefer a CADDX F2 or Foxeer Falkor here.
Foxeer Micro Falkor 2 1200TVL FPV camera - https://www.banggood.com/custlink/mvvv0aHs02
Caddx Turbo Micro F2 camera
- https://www.banggood.com/custlink/3vmG6GhUUK
The base plate with the arms is 3mm thick
duct propellers from the CineWhoop
iFlight MegaBee V2 3045 3 Zoll 3-blade Propeller - https://www.banggood.com/custlink/GmmDzETVB0
GoPro 6.7 camera holder. Unfortunately with a too large angle with over 25 degrees for a cinematic video
At the back an RHCP antenna with an SMA connector
Pro:
- Good flight behavior
- low cost
- good video transmitter 500mW HGLRC
- Good propeller protection made of plastic (not 3D print)
- F4 FC HGLRC
- 20A DSHOT600 ESC's HGLRC
Contra:
- bad 16: 9 FPV camera
- Betaflight not configured
- GoPro camera mount over 25 degrees
My Betaflight diff 2020-03-01 with ESC BlHeli 2.70
# 2020-03-01 BlHeli 2.70 8k 8k DSHOT600 profile 1 with rate profile 2
# diff all
# version
# Betaflight / STM32F405 (S405) 4.1.4 Feb 4 2020 / 17:25:51 (bc9715eec) MSP API: 1.42
# manufacturer_id: AIRB board_name: OMNIBUSF4SD custom defaults: YES
# start the command batch
batch start
# reset configuration to default settings
defaults nosave
board_name OMNIBUSF4SD
manufacturer_id AIRB
mcu_id 0052002f324d500220313256
signature
# name: CLOUD-149
# feature
feature TELEMETRY
# beeper
beeper -GYRO_CALIBRATED
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -GPS_STATUS
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# map
map TAER1234
# serial
serial 0 64 115200 57600 0 115200
serial 2 2048 115200 57600 0 115200
serial 5 0 115200 57600 0 115200
# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 2 1300 1700 0 0
# rxrange
rxrange 0 987 2011
rxrange 1 987 2011
rxrange 2 987 2011
rxrange 3 987 2011
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 5645 5885 5905 5925 5945
vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917
vtxtable powerlevels 3
vtxtable powervalues 0 1 2
vtxtable powerlabels 25 200 500
# master
set gyro_lowpass2_hz = 325
set dyn_notch_range = AUTO
set dyn_lpf_gyro_min_hz = 260
set dyn_lpf_gyro_max_hz = 650
set acc_calibration = 6,35,-139
set mag_hardware = NONE
set min_check = 1010
set max_check = 1990
set fpv_mix_degrees = 15
set serialrx_provider = SBUS
set dshot_idle_value = 400
set motor_pwm_protocol = DSHOT600
set motor_poles = 12
set vbat_max_cell_voltage = 450
set beeper_dshot_beacon_tone = 5
set small_angle = 180
set pid_process_denom = 1
set osd_warn_esc_fail = OFF
set osd_warn_core_temp = OFF
set osd_vbat_pos = 2498
set osd_rssi_pos = 33
set osd_tim_1_pos = 34
set osd_tim_2_pos = 2519
set osd_flymode_pos = 2487
set osd_throttle_pos = 321
set osd_vtx_channel_pos = 52
set osd_crosshairs_pos = 2317
set osd_craft_name_pos = 2506
set osd_warnings_pos = 2473
set debug_mode = SMARTAUDIO
set vtx_band = 4
set vtx_channel = 1
set vtx_power = 1
set vtx_freq = 5740
set gyro_1_align_yaw = 2700
set name = CLOUD-149
profile 0
# profile 0
set dyn_lpf_dterm_min_hz = 91
set dyn_lpf_dterm_max_hz = 221
set dterm_lowpass2_hz = 195
set feedforward_transition = 30
set p_pitch = 41
set d_pitch = 57
set f_pitch = 162
set p_roll = 38
set d_roll = 53
set f_roll = 153
set p_yaw = 45
set f_yaw = 111
set angle_level_strength = 40
set d_min_roll = 30
set d_min_pitch = 33
profile 1
# profile 1
set dyn_lpf_dterm_min_hz = 105
set dyn_lpf_dterm_max_hz = 255
set dterm_lowpass2_hz = 225
set p_pitch = 51
set d_pitch = 53
set f_pitch = 162
set p_roll = 47
set d_roll = 49
set f_roll = 153
set p_yaw = 42
set f_yaw = 111
set d_min_roll = 28
set d_min_pitch = 31
profile 2
# restore original profile selection
profile 0
rateprofile 0
# rateprofile 0
set yaw_rc_rate = 210
set roll_srate = 65
set pitch_srate = 65
set yaw_srate = 20
set tpa_rate = 50
set tpa_breakpoint = 1750
rateprofile 1
# rateprofile 1
set thr_expo = 40
set roll_srate = 60
set pitch_srate = 60
set yaw_srate = 60
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# restore original rateprofile selection
rateprofile 1
# save configuration
save
Original diff 2020-02-24
# diff all
# version
# Betaflight / OMNIBUSF4SD (OBSD) 4.0.4 Jun 30 2019 / 14:43:06 (f3a95efa3) MSP API: 1.41
batch start
defaults nosave
manufacturer_id
signature
# name
name CLOUD-149
# feature
feature -RX_PARALLEL_PWM
feature RX_SERIAL
# serial
# aux
aux 0 0 0 1300 1700 0 0
aux 1 1 1 1300 1700 0 0
# master
set acc_calibration = 103,86,-27
set dshot_idle_value = 300
set osd_vbat_pos = 2092
set osd_tim_1_pos = 2082
set osd_vtx_channel_pos = 2104
set osd_craft_name_pos = 2507
# profile
profile 0
profile 0
# rateprofile
rateprofile 0
rateprofile 0
save
My Kopterheld Coupons, on my Blog, Telegram or FB:
https://kopterheld.tv/
https://t.me/KopterHeld
http://bit.ly/KhFaceBo
My Equipment:
DJI Digital FPV System - https://www.banggood.com/custlink/mGvK0KF1Em
Fatshark Dominator HDO2 - https://www.banggood.com/custlink/KmGKeeY4pN
ImmersionRC RapidFIRE - https://www.banggood.com/custlink/vm3v6vafP1
Taranis X9D Plus SE 2019 - https://www.banggood.com/custlink/v3mKeGLLp6
Jumper 4IN1 Multimodule - https://www.banggood.com/custlink/vGvGNp7s07
FrSky R-XSR - https://www.banggood.com/custlink/DGvDgKOu8B
CADDX Ratel - https://www.banggood.com/custlink/KKKm6mLf9Q
Youtube – https://www.youtube.com/kopterheld
FB – http://bit.ly/KhFaceBo
Blog – https://kopterheld.tv/
RCGroups – https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Help! Reptile cloud cinewhoop issue WeazyMan Mini Multirotor Drones 3 Dec 13, 2019 12:40 PM
Discussion help needed with my cx 20 fatshark version after flashing firmware to version 149 idouglas Beginner Multirotor Drones 2 Nov 14, 2016 08:06 AM
