This thread is privately moderated by pdooley, who may elect to delete unwanted replies.
Mar 02, 2020, 02:29 PM
rc user
pdooley's Avatar
Data
Blue Bird Servo
namely, the bms-661dmg+hs
i provided feedback in this thread, been using these in ground vehicles for years, no servo saver and some pretty decent bashing. no failures to speak of other than broke the ears off one, but that was a full speed hit into a stationary object, hit hard enough to rip the a-arm off and break the center out of the wheel. that servo still works fine, just the case has no ears for mounting.
well yesterday another one failed. car started steering sluggish and then complete failure. the servo arm locked in place. i took it apart to find motor and probably board too was burned. gearset was fine but motor completely locked.
i did notice what looked like corrosion on the motor can, probably from water getting around the oring seals(not very good seals i noticed).
either way, the servo went for many hours before giving up. who knows how much longer it would last if kept dry. I have 3 others in service so will keep evaluating.
also will take the unbroken case from this dead one and fix the other, put it back in service.
Discussion New Blue Bird BMS-125WV Servo Neil Stainton Electric Sailplanes 10 Oct 10, 2019 07:59 AM
Mini-Review Blue Bird BMS-616MG+HS Standard 10kg 0.12sec Servo For RC Hobby Unboxing sim_tcr Electric Power Cars 0 May 03, 2018 12:08 AM
New Product New Blue Bird BMS-A10 F3K Servos ak79 Hand Launch 133 Jan 09, 2018 11:13 PM
Mini-Review New Blue Bird micro and mini servos REVIEWED! bradywatt23 Electric Plane Talk 5 May 22, 2016 11:20 AM
Discussion Fried mosfet or driver on Blue Bird servo BMS 2514 zenoid DIY Electronics 2 Jan 26, 2016 07:14 AM
