Mar 01, 2020, 08:27 PM
Battery alert on TinyHawk without goggles??
Hello everyone, great beginner here. I just bought a TinyHawk (1st version, not S) in the kit with goggles. I am first trying to learn to fly it line-of-sight, but I have a naive question: how do I know when to land the drone, to avoid damaging the battery? In the goggles there is a low voltage indicator, but how do you know when to land when you dont wear the goggles? Just using a timer set to 3:30 minutes? Thanks for your knowledge and experience, it is probably a silly question, but I really dont have any idea currently :-)
Mar 01, 2020, 08:36 PM
If it flies, I can crash it.
rocketsled666's Avatar
You need to learn about BetaFlight Configurator. This will let you see what the quad's low-voltage threshold is set to. It's probably around 3.4V/cell by default. If so, you can just keep flying until the quad lands itself. If not, set it to 3.4V and then just keep flying until the quad lands itself.
You may be able to add a buzzer or an LED to the quad to alert you to low voltage, but you'll have to read up on the TinyHawk flight controller to see if it supports one of these options.
Mar 01, 2020, 08:41 PM
Thank you rocketsled666! I will learn how to configure Betaflight then. My background is in computer science, so that part at least should be easier than piloting :-D I am not a native english speaker btw, so please accept my apologies for my mistakes.
Mar 01, 2020, 08:56 PM
I'd also recommend flashing jesc 48khz firmware to the esc for an additional :30-1:00 extra flight times
Mar 01, 2020, 09:10 PM
(googling googling) ... ok ... so "ESC" is the speed controller, so I understand that there is a better firmware to control it then? Thanks jay! Many things to learn in this hobby.
Mar 01, 2020, 09:13 PM
Yeah jesc 48khz reduces the amp draw on these tiny motors buy something like 30% with pretty much no drawbacks over the stock blheli configurator. It's pretty straightforward there's a few videos out there on it
Mar 02, 2020, 11:45 AM
just use the timer. how much los flying are you really going to do anyway?
Mar 02, 2020, 11:48 AM
Fan of just about anything RC
SoloProFan's Avatar
Is that a new feature? I've never seen a BetaFlight quad land itself if voltage hits the low voltage threshold. If it can no longer stay up in the air, that usually means the battery has been drained far too much, and usually the quad will not auto-land then, but just drop out of the sky.
Latest blog entry: For the love of the hobby!
Mar 02, 2020, 05:56 PM
Yeah, flying till you can't is bad advice. BF has no low voltage cutoff feature that I know of. Only thing you can do is set warnings.
Pretty sure the tinyhawk flight controller has pads for a buzzer. I would add a buzzer, then you can set it in BF to sound at the LV warning. Having a buzzer comes in handy when you start flying fpv anyway.
Mar 02, 2020, 06:03 PM
Name: ummagawd-acrobrat-mamba-f4-mini-fc-betaflight-settings-power-voltage-current-meter[1].jpg
Description:
You'll notice a Warning Cell Voltage that is separate from Minimum Cell Voltage. I'm pretty sure when you hit minimum, BF will land even if you're pushing the throttle to the top.
Mar 02, 2020, 06:06 PM
Not true. There are separate warnings for low voltage and minimum voltage is all. Like a pre-warning. In the osd they show as "low voltage" and "land now". But nothing stops you from flying through them.
Mar 02, 2020, 06:15 PM
SoloProFan's Avatar
Attachment 13224429
"Pretty sure" may be enough in some cases, but not here. As the quoted reply below this correctly states, the two different values only translate in a different memory being displayed on the OSD. The only thing that will force a BetaFlight quad to land is a fully drained battery. If you don't fly FPV, and there is no buzzer installed, to be able to sound a warning when the voltage gets low, a timer is the only way to prevent over-discharging the battery.
Mar 02, 2020, 11:35 PM
My quads mostly seem to behave as if it works that way. But honestly, I've never paid it a huge amount of attention. I'll watch more carefully when I go flying tomorrow.
Sorry for any inaccuracies in my comments!
Mar 03, 2020, 12:58 AM
SoloProFan's Avatar
I understand why you thought it would work that way. And we all keep learning.
Mar 03, 2020, 02:54 AM
There's really no reason why it shouldn't work that way. At least as an option you could turn on.
Discussion Should goggles power on without receiver? Tacomaty FPV Talk 1 Apr 25, 2019 05:58 PM
Discussion receiver not powering on in betaflight without main battery bigblock81 Beginner Multirotor Drones 8 May 11, 2017 09:54 PM
Using battery checker on 2S battery without balance connector espana23 Batteries and Chargers 13 Feb 22, 2017 12:15 AM
Discussion Does Mobius give on screen Low Battery alert? shaunmed Aerial Photography 3 Mar 18, 2014 02:24 PM
Alert Alert - Video Goggles on Woot for $90 Zirt57 FPV Talk 19 Mar 22, 2009 07:03 PM
