This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Feb 29, 2020, 11:50 PM
Merch's Avatar
Mini-Review
GEPRC CinePro 4K HD 3-4S FPV Racing Drone PNP/BNF F405 FC Caddx Tarsier 4K 30A ESC
GEPRC CinePro 4K HD 3-4S FPV Racing Drone Basic Version PNP/BNF F405 FC Caddx Tarsier 4K 30A ESC 5.8G 48CH 0~500mW VTX - DSMX/DSM2 R720X
Link
What a great Quad full review to follow.
We are glad to introduce you to CinePro 4K, which can accomplish some tasks that traditional aerial photographic aircrafts can not do. It is lightweight, compact and capable of recording 4K@30fps video with excellent quality and moving colors.
CinePro 4K uses the improved GEP-CX2 frame and newly designed propeller guard. It has perfect aerodynamic performance, safety, durability and high efficiency.
In terms of power system, we use GR1105 kv5000 motor, which is balanced, smooth and very suitable for aerial photographic quads. It is recommended that 4S battery be used to achieve the best efficiency. 4S 450mAh battery for indoor, 4S 650mAh battery for outdoor. The safe flight time is more than 4 minutes.
CinePro 4K is carefully assembled and debugged by GEPRC team. The BNF kit is bind & fly, the PNP kit needs your own receiver.
Specification:
Frame:GEP-CX2(Improved version,Including Guards)
STABLE V2 F405
Camera:Caddx Tarsier 4K 1200TVL
Motor:GEP-GR1105 5000KV(4S lipo battery is Best)
Propeller:EMAX AVAN 2Inch or DalProp Q2035 4-blade
VTX 5.8G 500mW
Weight:Around 125g(without battery)
STABLE V2 F4 Flight Controller Specs
Model:STABLE V2 F4 30A
MCU: F405
IMU: MPU6000 gyro/accelerometer (SPI)
OSD: BetaFlight OSD w/ AT7456E chip
Baro:NO
BEC Output: 5V@3A
Integrated LC Filter
Firmware target: OmnibusF4SD
Size: 26x26mm board, 20mm mounting holes (M2)
STABLE V2 F4 ESC 2-5S 4in1 Specs
Input:2-5s lipo
Constant:30Amps
Burst:35Amps
Dimensions:31*31mm(including the power pads)
Mounting Holes:20*20mm,M2
Supports Dshot600,Proshot,Oneshot,Multishot
Current meter: Yes
Target: G_H_30
STABLE F4 5.8g 500mW VTX Specs
Input voltage: 5V
Channel: 48
Power transmission: 0mW(Pit mode) / 25mW / 100mW / 200mW / 400mW/ 500mW
Size: 24 * 26 mm
Mounting Holes Dimension: 20mm x 20mm
Connector type: MMCX Connector
BEC Output: 5V/1A for Camera of FC
Weight: 2.3g
Traditional button
IRC Tramp protocol
Feature:
HD Video Recording: 4K@30fps, 2.7K@60fps, 1080P@90fps.
Dual Camera System: 1200TVL FPV camera of competition-level, low latency within 10ms.
WIFI/APP support: Video recording parameters are adjustable by WIFI/APP.
Basic Version: F405 Flight Controller, STABLE V2 F405 30A.
Black Box: 32Mb onboard flash memory.
500mW VTX Power: Effectively improves your flight distance.
Aerial Photography Friendly: No sight of propellers and propeller protection frames in your video.
Full Soft Mounted FC System: Provides a clean operating environment for gyro.
Say Goodbye to Jelly: Stable video, and comfortable FOV.
Improved GEP-CX2 Frame: Full 3K carbon fiber, 7075 aviation aluminum, High-preci sion CNC. Rugged and durable frame, Better protection for the 4K camera.
New Propeller Guard: Better airflow, Higher flight efficiency.
High Efficiency Motor: GEP-GR1105 5000KV Motors, 4S battery (450-650mAh) recommended.
Taillight Design: Eye-catching night view and lighting effects.
Exquisite Assembly Process: Eliminate any potential installation problems.
Recommend Parts:
Protection Ring 60mm Diameter 25mm Height
R9MM T Type TBS Crossfire 3D Printed Parts
3mm Carbon Fiber Upper / Bottom Plate
GEPRC STABLE F411
Package Included:
1 x CinePro 4K Basic Version F405 FC FPV Racing Drone (PNP/BNF Optional)
1 x EMAX AVAN 2inch PROP(SET)
1 x DalProp Q2035 4-blade(SET)
Discussion Eachine LAL5 225mm 5 Inch 4K 6S FPV Racing Drone PNP F405 Bluetooth FC Caddx Tarsier alex_nikiforov Banggood.com 3 Oct 18, 2019 10:52 PM
Discussion GEPRC CinePro 4K HD 3-4S FPV Racing Drone Basic / Advanced Version PNP/BNF alex_nikiforov Banggood.com 19 Sep 14, 2019 09:23 AM
New Product iFlight iH3 4K HD 2-4S 3 Inch FPV Racing Drone BNF/PNP Caddx Tarsier 4K Cam SucceX F7 alex_nikiforov Banggood.com 0 Jul 10, 2019 08:58 AM
Discussion TTMC AirBlade 3inch 4K 150mm HD 3-4S PNP 160g FPV RC Racing Drone CADDX Tarsier 4K Merch Banggood.com 0 Jun 17, 2019 05:32 AM
New Product Geprc CinePro 4K FPV Racing Drone With F7 Dual Gyro 2-6S 35A BLheli_32 Caddx Tarsier scousethief Vendor Talk 0 May 28, 2019 06:05 AM
