Feb 27, 2020, 04:49 AM
headshot001's Avatar
Question
SAFE into larger heli
Is t possible to install a SAFE receiver like an ar636 Into a 450 size heli for the self leveling feature? What other manufacturers offer similar stabilization? I am new to helis just not rc.
Feb 27, 2020, 05:33 AM
Heligamist
BrokeDad's Avatar
I wouldn't put an AR636 in a larger heli. If it's set up for a motorized tail it probably won't work at all. You'd be best off with something like a Spirit FBL that has stability modes and rescue. I have several of those in larger models.
Feb 27, 2020, 01:26 PM
UK 550/600 Tarot distributor
Smoggie's Avatar
Most modern flybarless controllers have stabilisation capability similar to SAFE. On some you need to pay extra to turn on the feature, but on the Spirit or the ikon/Brain it comes 'free'.
Note that a flybarless controller is not a receiver, with a few exceptions you have to add a seperate receiver.
Feb 28, 2020, 05:17 PM
I guess a Spektrum 7210bx is safe capable with an upgrade. What would be another equivalent?
Feb 29, 2020, 06:32 AM
Heligamist
BrokeDad's Avatar
Yes but for the price of the upgrade alone you could buy a used Spirit or Brain/Ikon.
Mar 01, 2020, 11:12 AM
Ok, so other have a self leveling ability. Itís difficult reading the product descriptions which offer self leveling and a recovery function. It also appears most require a separate receiver and some require adapter to use Spektrum receivers?
Mar 01, 2020, 11:32 AM
Heligamist
BrokeDad's Avatar
They use what's know as a satellite receiver. They aren't very expensive. You can even get ones that will send telemetry to your radio (although they cost a bit more) like the AR4649T and the newer AR4650T. Here is a Lemon RX sat receiver on Amazon for $15.99. It will plug directly into a Brain/Ikon or Spirit FBL.
https://www.amazon.com/Compatible-Di.../dp/B016RP8XLO
Discussion Flying larger Rc helis by yourself? Coopz Electric Heli Talk 57 Apr 03, 2018 08:27 AM
Discussion How to intall heli stabilizer into regular Trex450 heli? congcon97 Mini Helis 6 Jul 29, 2017 07:04 AM
Discussion Dumb question...of a newbie into heli Rc's....3D helis can do only scale flights? targetingxmod Micro Helis 18 Sep 29, 2016 03:35 PM
PFM is looking to expand into the larger scale aircraft. WJ Birmingham Sport Planes 12 Jan 02, 2004 10:31 PM
