Feb 24, 2020, 09:45 PM
Motor water proof
Interested in buying eBay thruster for rov and bait boat, so basically what I saw are just brush less motor mounted on base with propeller bolt on shaft, no water seal at all. Are those motor will last reasonably long? Just run them in water and dry after will be enough to keep them?
Feb 25, 2020, 12:35 PM
Depends on both the water and the motor. Lubricating after use as well as drying, if it is salt water insulation checks will be needed as well.
Feb 28, 2020, 01:37 PM
Out of the way, Peck!
Buy any brushless motor, replace the bearings with ceramic bearings, coat the stator wires with epoxy resin thinned with denatured alcohol to keep the copper isolated from corrosives such as salt water. Rinsing with fresh water post-mission is a good idea.
Boat props are formed to be very efficient in forward, but they are very inefficient in reverse. An ROV prop needs to run both forwards and reverse alot, so the prop works better if the blades are symmetrical. Try buying a 6-blade EDF and cutting off 3 blades. Water is alot thicker than air, so a 3-blade prop is the most efficient. https://www.amazon.com/JFtech-6-Blad.../dp/B07C2BST4M
Since water is so much harder to move than air, you need a high-torque brushless motor. 2200kv might be good for a quadcopter (drone), but they overheat (or the ESC does) when trying to move a heavy ROV through thick water. Look for low-kv motors, like this 400kv one... http://www.valuehobby.com/power-syst...outrunner.html
As well, a 20-amp ESC might be fine for a drone in air, but you'll need a higher-amp one for water. If you coat it with epoxy resin you can even immerse it in water for cooling. Or fill a separate WTC with mineral oil (which is non-conductive) and put the ESC's in that. I use aluminum pipe for my WTC's because it transfers heat to the surrounding water the best and just coat every surface in epoxy. https://www.amazon.com/GoolRC-Brushl...dp/B07SZRW229/
Discussion Proof That Using Salt Water to Discharge a LiPo Does Not Work JimHSoars Batteries and Chargers 13 Nov 02, 2018 10:06 PM
Help! water proof Tx for surfboard leadfeather Power Systems 1 Jun 12, 2016 08:31 AM
Discussion Water proofing my smash shark. tearuck Racing Boats - Electric 4 May 30, 2016 11:52 PM
Video How To water proof RC electronics reptileman Off-road Cars 5 Jan 04, 2016 08:40 AM
Discussion Sidewinder Water Proof? Motor? Bohh33 Castle Creations 2 Aug 18, 2008 10:47 AM
