Feb 24, 2020, 02:42 AM
Just Plane Nutts
AirDOGGe's Avatar
Volantex Super Cub - 2S brushless / 4-channel upgrade
I finished my project to make a Volantex Super Cub 500 into a REALLY super Cub. Why they named the 4-channel version "Sport" and the 3-channel as "Super" is beyond me, but I fixed that.
Ingredients in this performance stew include full-span balsa ailerons and a 10mm brushless inrunner fed from an eFlite brick with built-in ESC and AS3X stabilization. Separate 1.7g servos handle rudder and elevator duties.
The wing struts were remove to reduce drag, and a 2mm carbon rod epoxied within to assume the wing-reinforcing role and make the wing a cantilever type. The wing itself is removable now, held in place by a single nylon screw and by a short section of carbon rod at the trailing edge.
Performance is........ Well, it's WOW! I can't believe how quick it is now. Straight up performance is like a NASA rocket. Rolls and inverted turn-arounds are easy as breathing. I'm VERY happy with the results. I can finally make it do what I WANT it to do, and still have gyro stabilization to deal with the local and persistent bay winds.
I believe the correct term to use here is, "Happy-Happy, Joy-Joy!"
Happy flying! Build details and first flight videos shown below.
Part 1 - Fuselage mods
Volantex V761-3 Super Cub 500 mod (4 min 18 sec)
Part 2 - Wing mods
Volantex V761-3 Super Cub 500 mod - Part 2 (4 min 18 sec)
Part 3 - First Flights
Volantex V761-3 Super Cub 500 ...... Brushless 2S / 4-channel mod (6 min 21 sec)
Feb 24, 2020, 01:58 PM
Where did the motor come from.
Feb 24, 2020, 02:45 PM
Well done and great presentation !
Feb 24, 2020, 06:56 PM
Just Plane Nutts
AirDOGGe's Avatar
eFlite 10mm outrunner. Plugs right into the 2S-powered AS3X board. You can see it in the first video: https://www.ebay.com/sch/i.html?_fro...0MDFB&_sacat=0
Note that I had to drill out the brass pinion gear to fit the 1.5mm shaft on the inrunner motor. The stock 10mm brushed motor has an odd 1.2mm shaft.
And the rear-mounted servos helped to balance the heavier motor up front. Keep and eye on C/G changes.
My next brushless mod will be a Eachine Mini Mustang with a direct-drive motor. I already have a replacement P-51 fuselage and wing to build it with rather than tear down an existing Mustang, and I am testing and deciding on suitable outrunner motors. More to come.
Feb 24, 2020, 07:31 PM
Thank you for your reply, I have all the parts.
John
Feb 25, 2020, 12:38 AM
Just Plane Nutts
AirDOGGe's Avatar
No problem. I hope to see photos...
Mini-Review Volantex Sport Cub 761-4 Stabilized 4 Channel Trainer Airplane Flight Test Review t00nz843z Micro Ready-to-Fly 13 Mar 16, 2020 02:32 PM
Discussion Successfully upgrade Sport Cub S to 2S brushless while keeping SAFE necbot Micro Ready-to-Fly 31 Feb 10, 2020 02:20 AM
