Feb 24, 2020, 12:41 AM
K&B 6.5CC DF motor, It lives! :)
Hey engine nuts, before I destroy this nice little engine that needs new bearings;
1.How do you take the front machined Alu. hub off?
2. Can one change it to different short hub, and is it available, to make it into a prop plane engine?
Feb 24, 2020, 01:46 AM
AMA 46133
SeismicCWave's Avatar
If the KBV 82 is any indication I would say probably a tapered collet is holding the prop drive hub.
The closest thing I found is a K & B .48 ducted fan engine in MECOA. Here is a link to the exploded diagram and yes it is a tapered collet holding the prop drive hub.
http://www.mecoa.com/kb/48/4825-exp.pdf
MECOA also has a K & B .48 aero engine listed. Here is the exploded diagram.
http://www.mecoa.com/kb/48/4800-exp.pdf
So in theory you can get the collet and the drive hub for the aero engine and fit it on the ducted fan? Ok you don't even need to change the collet. They are both the same part number. Just buy the shorter drive hub for the aero engine 20-4801 and you should be able to use a prop on it.
Feb 24, 2020, 02:00 AM
Thx man. I did look at the Meccoa site and didn't even see the 6.5CC, they had the 7.5CC so I wasn't quite sure. Although I suspect the 6.5CC and the 7.5CC may share many parts. I'll order some bearings soon and check out that 20-4801
Feb 24, 2020, 06:04 AM
GloBroz PowerLab
1QwkSport2.5r's Avatar
Chances are the only differences between the .40 and .45 is the crankshaft and/or piston/liner.
Get ready - they’re screamers. Don’t forget the speeders mantra. RPM RPM RPM!!!!!!!!!!!
Feb 24, 2020, 06:41 AM
I had the 7.5 for a few years but sold it when someone offered me more than I could turn down.
Feb 24, 2020, 10:00 AM
GloBroz PowerLab
I wouldn’t mind finding a 3.5cc DF/Marine engine sometime. I have a boat that needs more oomf than the OS 21 SE-M can muster.
Feb 24, 2020, 10:32 AM
Scott
Pylonracr's Avatar
Tim, I have your 3.5 marine engine. Never run. Send me a PM.
Scott
Feb 24, 2020, 02:18 PM
A few months ago, I ran my K&B 3.5CC FIRE Aero on a test stand, it just loved to rev with a regular muffler, I was worried the prop blades may depart!
Feb 24, 2020, 02:56 PM
GloBroz PowerLab
My buddy has one of those engines - we broke it in on the bench one day with a short pipe. Holy cow!! It staged the pipe at 22k and was full on the pipe at around. 26-27k. There was no in between - it was either 22,000 or 26,000+.
Feb 24, 2020, 03:38 PM
I can't remember if mine had a Perry pump or not, I may be confusing it with my K&B 7.5CC motor, but my 3.5CC is not a DF engine, just a regular one with that funky cross muffler with dual exhaust outlets.
Feb 24, 2020, 04:29 PM
Scott
Pylonracr's Avatar
The marine engine I have has that muffler, exhaust throttle, and a venturi.
Scott
Feb 24, 2020, 05:12 PM
GloBroz PowerLab
Scott
My buddy’s 3.5 engine came with that dual outlet muffler too. It would have run like crap on that muffler with how the engine is timed. It definitely liked the short pipe we had on my buddy’s.
Hey Scott. I sent you a PM.. where’s my reply?
Jackass™️
Feb 24, 2020, 05:34 PM
Scott
Pylonracr's Avatar
Jackass™️
Oh, I answered your PM....
Jackass
Scott
Feb 24, 2020, 06:21 PM
GloBroz PowerLab
Jackass
Scott
Took ya long enough.
Feb 24, 2020, 07:43 PM
I had to use this auto oil filter removal tool to get the stuck sleeve of the case.
Discussion 3.5cc K&B Gold Series Outboard Racing Motor and Tunnelhull FOR SALE Tbone2000 Racing Boats - Internal Combustion 7 Dec 07, 2018 05:17 PM
Question K&B 6.5cc question CryHavoc Engines 2 Feb 16, 2016 11:45 AM
Discussion outboard 3.5cc ; will any 3.5cc marine nitro motor work hsp-sandiego Racing Boats - Internal Combustion 4 Sep 20, 2013 03:26 PM
Question Axi-Flow RK40 DF kit & K&B 7.5cc engine? Skiddz Fuel Jet Talk 8 Nov 23, 2010 06:32 PM
Help! K&B 6.5cc Rear Exhaust engine... Info? NickBell Engines 3 Jul 08, 2007 10:01 AM
