Feb 23, 2020, 12:22 AM
Bookstar75's Avatar
Question
Motor and Prop for Max Efficiency?
Hello,
Im looking for advice on a motor and prop combo for long range efficiency. I frequently fly out 5 miles with my Sonicmodell Wing with a pair of Ion lipos and can stay up for 20 minutes.
But im looking for a more efficient motor and prop recommendation.
Thanks!!
Feb 23, 2020, 12:18 PM
Originally Posted by Bookstar75
Hello,
Thanks!!
It would be helpful to have more detailed information on the model and its current power setup.
What specific model is it?
How much does it weigh all up?
Approximate wing area and wing span?
Current prop make, diameter, pitch and number of blades?
Specific motor model and specs?
Battery voltage, mAh capacity and weight?
Room for larger battery?
Any limits on prop diameter?
Feb 27, 2020, 05:41 AM
Wake up, feel pulse, be happy!
Piece's Avatar
The general formula for long range is large diameter, low RPM, and as much pitch as you can get.
Latest blog entry: Jeti ESC resto-mod
Question Hull design and prop/motor choice for high efficiency boat? Whoshahore Dock Talk 22 Aug 15, 2019 06:30 PM
Discussion max efficiency motors for tarot FY650 on 4 cells. bjornthans Multirotor Drone Power Systems 5 Sep 28, 2013 08:02 PM
Discussion Max Copper fill Vs. Motor Cooling for Efficiency wingnutt Electric Motor Design and Construction 26 Jul 17, 2011 06:04 AM
Discussion Max efficiency motor/prop vh2q Electric Plane Talk 43 Oct 20, 2010 08:16 PM
