This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Feb 21, 2020, 09:57 AM
Merch's Avatar
New Product
Eachine UZ65 65mm 1S Whoop FPV BNF Runcam Nano3 35mm Props 5.8G 25~100mW VTX
21g Eachine UZ65 65mm 1S Whoop FPV Racing Drone BNF Runcam Nano3 35mm Propeller 5.8G 25~100mW VTX - Internal SPI Frsky Receiver
Link
Will it be better than the Mobula6?
Specifications:
Brand Name: Eachine
Item Name: UZ65 65mm FPV Racing Drone
Wheelbase: 65mm
Weight(without battery): 21g
Weight(with battery): 29g
Receiver option:
Internal SPI Frsky version (Compatible with ACCST D8/D16, Recommend D8 mode)
Internal SPI Flysky version(Compatible with AFHDS and AFHDS-2A Flysky transmitter)
External DSM2/DSMX Receiver version(Compatible with Spektrum DX6I/DX7/DX8/DX9)
External TBS Crossfire Nano RX version(Compatible with TBS transmitter)
Features:
The smallest 1-2s 3 in 1 flight controller built-in ESC, Receiver
The world first 65mm whoop with 35mm propellers
Runcam Nano3 The lightest 1/3 CMOS 800TVL Camera
Smooth and powerful
Compatible for 1S Lipo/LIHV
Camera Angle adjustable
Spare parts specifications:
Motor
Mode: SE0802 19000KV
Configu-ration:9N12P
Stator Diamter:8mm
Stator Length:2mm
Shaft Diameter:Φ1mm
Motor Dimension(Dia.*Len):Φ10.5mm*14.9mm
Weight(g):1.9g
No.of Cells(Lipo):1S only
Propellers
HQPROP 35mm-3blades
Center Thickness:5mm
Prop Diameter:35mm
Center Hole Inner diameter:1.0mm
Flight controller
Frsky SPI RX version Firmware target: CrazybeeF4FR
Flysky SPI RX version Firmware target: CrazybeeF4FS
DSM2/DSMX External RX version Firmware target:CrazybeeF4DX
TBS Crossfire External RX version Firmware target: CrazybeeF4DX
MCU:STM32F411CEU6 (100MHZ, 512K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Power supply: 1-2S battery input (DC 2.9V-8.7V)
Built-in 5A(each) Blheli_S 4in1 ESC Dshot600 ready
Built-in Betaflight OSD(SPI Control)
Built-in SPI Frsky/Flysky receiver
Built-in 5V 1A BEC
Built-in voltage detection
Onboard 4in1 ESC
MCU upgraded to EFM8BB21
Power supply: 1S LiPo/LiPo HV
Current: 5A continuous peak 6A (3 seconds)
Support BLHeliSuite programmable
Factory firmware: O_H_5_REV16_7.HEX
Default protocol: DSHOT600
Onboard Frsky SPI D8 receiver Version
SPI BUS receiver Frsky D8 compatible
Compatible Non EU transmitter D8 model
Channels: 8ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 100m~200m
Onboard Flysky SPI receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
No ground interference ( Transmitter and receiver 1 m from the ground): 100~200m
Failsafe support
5.8G VTX
Output power: 25mw~100mw
Frequency: 40CH
Input voltage: 3.3V~5.5V
Current consumption: 300mA(type)
Frequency: 5.8GHz 5bands 40 channels
With Race band
Smartaudio ready
Runcam Nano3
Model: RunCam Nano 3
Image Sensor: 1/3" CMOS
Horizontal Resolution: 800TVL
Lens : 2.1mm(M8) FOV 160°
Signal System: PAL/NTSC Non Switchable
S/N Ratio: >50dB
Electronic Shutter Speed: Auto
Auto Gain Control (AGC): Auto
Min. Illumination: 0.01Lux@1.2F
D-WDR: Auto
Day/Night: Color
PowerC 3-5.5V
Current: 110mA@5V 120mA@3.3V
Housing Material: ABS
Net Weight: 1.2g
Dimensions: L14mm*W14mm*H9mm
Lipo Battery
Capacity:300mAh
Voltage:3.8v
Continuous Discharge Rate: 30C
Weight: 8g
Connector: PH2.0
Package includes:
1 x UZ65 65mm 1S 65mm whoop Drone Frame
1 x SPI Receiver Option1: Superbee F4 FC built-in Frsky SPI D8 RX
SPI Receiver Option2: Superbee F4 FC built-in Flysky SPI RX
External Receiver Option3: Superbee F4 FC built-in DSM2/DSMX RX
External Receiver Option4: Superbee F4 FC built-in TBS crossfire RX
4 x SE0802 KV19000 brushless motor
1 x HQPROP 35mm-3 blades Propellers(4cw+4ccw)
1 x Runcam Nano3 1/3 CMOS 800TVL camera
1 x 5.8G 25mw-100mw 40ch vtx
4 x 1S 300mah 30C LiHV Battery
1 x 1S Lipo/LIHV USB Charger
1 x Propeller disassemble tool
1 x Eachine Handbag
Feb 22, 2020, 05:07 AM
Sumfear's Avatar
New Mobula6 from Eachine? I looks the same.... I tried the Mobula6 and it is great:
MOBULA6: un campeón de 20gr (8 min 27 sec)
Feb 22, 2020, 12:59 PM
That thing can take a 2S battery?
Wonder how that's going to fair with the 19k motors... I bet the voltage sag would be too ridiculous.
I like the 100 mW VTX option though
Feb 24, 2020, 12:29 AM
Merch's Avatar
https://youtu.be/6xpmfQc3C9o
Yes the Mob6 is great my main review is here https://www.rcgroups.com/forums/show...3#post43432539
It's compatable with 1s only i think they made a missprint nothing new..........lets see how good the VTX is when the reviews come out but i can say my Mob6 has great VTX powa for 25mw.
New Product Eachine Lizard95 95mm F3 FPV Racer ( 4 in 1 10A ESC OSD 5.8G 48CH 25MW/100MW VTX 60 ) RDroneW Micro Multirotor Drones 3879 May 23, 2022 07:44 PM
New Product AuroraRC Supra-VTX 5.8G 40CH 25mW 100mW 200mW Switchable FPV Transmitter VTX for Supr alex_nikiforov Banggood.com 0 Jun 13, 2019 05:37 AM
New Product SPC Maker Mini Whale 78mm Micro F4 FPV Racing Drone PNP BNF w/ 25/100mW VTX Runcam Merch Banggood.com 2 Apr 16, 2019 05:44 PM
Discussion Eachine TX805 5.8G 40CH 25-800mW FPV Transmitter VTX Support OSD/Pitmode/Smartaudio BobFromMars Banggood.com 0 Aug 05, 2018 09:59 PM
