This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Feb 20, 2020, 05:38 PM
old4570's Avatar
Project Bee ( 490mm Wing )
Project B
This is a flying wing that comes in a twin pack ( 2 wings ) , I got mine from banggood .
I really like twin packs .
Building the wing gives me what appears to be a strong and stiff platform that will stand up to some bumping and grinding . The Bee is suggested to be for FPV , but with everything hanging out in the breeze so to speak I was quite happy to build mine for line of sight flying .
The Motor
Quite simply a offering from my defunct x450 . Motor and prop are x450 left overs . When I did some motor testing the x450 motor prop combo pulled some 2.18A for some 121g of thrust @ 12,000 rpm . I did some more testing and
6x3 Gemfan 2s = 2.8A / 156g / 22.5w / 10,500rpm
5x3 Gemfan 2s = 2.44A / 133g / 20w / 11,700rpm
6x4.5 2s = 4.4A / 180g / 36w / 8100rpm = Too much prop
5x3x3 2s = 2.6A / 142g / 21w / 11,500rpm
x450 prop 2s = 2.18A / 121g / 18w / 12,000rpm
I will have to check the current to the motor in the model as it is a different motor to whats on the test stand . ( Back up current draw )
ESC
Quite simply the cheapest 10A Ebay ESC I could buy . The motor wires are soldered directly to the ESC and I was lucky that the motor ran in the correct direction the very first time .
Servos
Some small Turnigy I had lying around . The first servos I used were some Ebay ones ( 3.7 or 4.3g ) and unfortunately one of the servos was dead as a do-do bird . So I was forced to replace them with the Turnigy . Nothing was glued in yet so replacing them was easy .
Battery
Hmmm , I wanted to use the 300mAh ones from the OMPHobby T720 , but the x450 motor was too heavy . So I ended up with the 500mAh one from the Volantex Decat .
Flying weight
Flying weight is almost on the nose for 108 grams , which for me is a little porky pig for a 490mm wing . Though no where near as bad as if I had built it as suggested by the factory .
The C of G
As near as I can tell , factory recommendation is about 110mm from the nose . Currently my CG is around the servo leads . ( Maybe too hot ? )
I have not glud tested or flown the Bee yet as it has been raining last night and the ground is sloppy wet ! No wind to speak off , but all that water on the ground ? The battery is charged , the Rx bound and the Tx set up .. Hopefully ASAP
Feb 22, 2020, 05:09 AM
old4570's Avatar
CG Games ...
The 500mAh 2s battery brought the CG to 120mm from the nose ...
This was literally impossible .
I have a 900mAh battery that will bring CG to 110mm ( Factory Recommendation ) , but I think this too will ( might ) be too far back . Then there is the 1000mAh Nanotech that will bring CG to about 100mm from the nose ..
Next time out ( probably tomorrow morning ) I will take the 900mAh and 1000mAh batteries with me .
CG without a battery is around 150mm from the nose , I would suggest this is way too far back if you want to run a smaller , lighter , battery .
Without a test bunny , who knew ?
Feb 18, 2021, 07:07 PM
Quad Erat Demonstrandum
scousethief's Avatar
Getting CG on this one is a fight in itself, with only servos installed and a 2s 700mah batt the balance is spot on, problem is I now need to add a motor and esc and keep the balance on the CG. I will probably have to add some dead weight even with a micro quad motor. The other idea is to add a protective bubble/canopy which will let me add some weight up front and balance out the motor. A shame as I wanted to try and build ultra light.
Feb 19, 2021, 04:20 PM
old4570's Avatar
If the weight comes too high , slow flight suffers .
The next one will be a sub 100 gram project , how sub ?
A small 1306 should be plenty mojo , I have a few 1306 lying about , maybe even a 1106 .
If you build under 100 grams , then any motor that produces 100 grams of thrust should do .
Discussion Bee 490mm wing kit ( 2x Wings ) old4570 Flying Wings 13 Aug 14, 2020 11:28 AM
Discussion Building a custom wing for a Canard Rotor Wing (School project) lightshade Composites Fabrication 6 Jan 23, 2020 11:48 PM
Build Log Albatros D.III 490mm Mike Payne Scratchbuilt Indoor and Micro Models 19 Feb 11, 2016 09:00 AM
Discussion My recent project wing + aerial video catman529 Foamies (Scratchbuilt) 0 Sep 21, 2015 03:59 PM
