Feb 18, 2020, 12:47 PM
Help!
Zelos 36 twin
Hi can anyone help my motor mount plates have melted and I was told that they come with the boat and there not available to buy any where you have to buy a new hull .has anybody had this problem ,if so how did you solve it. I brought this boat 2nd hand but it's never been in the water .help .thanks
Feb 18, 2020, 02:29 PM
RCexplained on YouTube
My recommendation is try contacting HorizonHobby. Ask them for a part number to make an order.
Feb 19, 2020, 12:10 PM
Zelos 36
Hi I've contacted them and the 2 motor mount trays that I need come already in the hull. You can't buy them only a new hull so it 450 in the bin .do all the parts fit into a miss geico .thanks ray
Feb 19, 2020, 06:37 PM
There's got to be a way to build your own motor mounts out of wood or even 3D printed and then glass it in to the hull. That would be very cheap.
Which Miss Geico hull? There is a Zelos Miss Geico. It's nearly the same hull.
Feb 19, 2020, 08:45 PM
It would be nearly impossible for the motor mounts to be melted unless your motors actually caught fire and even then it would be hard for them to melt due to the fact that they are mounted to aluminum mounts and then they are bolted to the plastic mounts. Are you talking about where the stuffing tube comes through the mount? If so align it put epoxy around the stuffing tube re-align the motor mount and you're good. If not you will have to cut the whole mount out and install your own mounts which won't be fun. The Geico 36 and Zelos 36 are the same hull with different motors, drive cables, stingers, and motor mounts.
Feb 20, 2020, 07:49 AM
Zelos 36
Hi yes it's where the stuffing tubes go through .thanks for your advice .ray
Feb 20, 2020, 07:26 PM
Place some small pieces of popsicle sticks in the melted gap as shims around the stuffing tube to make it align as close as you can to the motor collet and then fill around it with 2 part epoxy (slow cure) and you will be good to go and with more heat resistant than it was from the factory. Don't forget when you flip the boat more times than none the motors will shift. I draw a line on the mounts when I know they are right and go by that line to check before I send it. Good luck with it.
Discussion Pro Boat Zelos 36 Twin Brushless Catamaran RTR Rafael_Lopez Racing Boats - Electric 1164 Sep 11, 2019 10:18 AM
Build Log Zelos 36" Twin - Full Build Noobz Racing Boats - Electric 5 Aug 26, 2019 09:01 AM
News Pro Boat Miss GEICO Zelos 36" Twin Brushless Catamaran Jason Cole Racing Boats - Electric 41 Aug 18, 2019 07:36 AM
News Pro Boat Zelos 36 Twin Catamaran BL RTR Matt Gunn Racing Boats - Electric 33 Dec 16, 2017 12:12 AM
