Feb 18, 2020, 04:33 AM
Minimum pressure for infusion?
I've looked around and I can't seem to find a good answer as to if there is a minimum pressure for resin infusion?
I just finished my infusion setup/machine and it looks like my (freshly rebuilt) wobble pump can only reliably pull -24 inches.
What you think?
Feb 18, 2020, 11:03 AM
Are you looking for a single number?
This is a process and many variables need to be considered.
What do I think? Wherever your looking around is not the right place. The internet is full of information.
Feb 27, 2020, 12:14 AM
No place like cloud base!
24" is on the low side, but i have successfully infused a heavy glass layup at that vacuum level before. You may need to restrict the resin flow by partially clamping the fill line. This will help maintain vacuum over the lay up and prevent flooding.
Mar 03, 2020, 08:56 AM
Barney Fife, Vigilante
tom43004's Avatar
There are about a thousand variables involved, but yes I agree... with most materials and at room temperature 24" is probably lowish... but I am by no means an expert at it.
Mar 05, 2020, 10:10 PM
hawaiianspork226's Avatar
Have infused successfully at 10" hg before with a variety of layups. Usually it comes down to what viscosity the resin has. We were using polyester and or vinylester resins, they tend to haveuch lower viscosities than epoxies. Methacrylates can work well with lower pressures too.
A benefit of infusing at lower pressures is that the laminate is less compacted, resulting in decreased resistance to flow within the laminate... BUT it also means the resin isnt being pushed as hard by atmosphere, so flow is still slow
Basically if there is ANY pressure differential between atmosphere and within the infusion cavity, there will be flow... It's just whether or not it's enough to move enough resin through enough of the laminate to get a part to turn out correctly...
Hope that wasn't too much word salad...
But at the end of the day, with epoxy, higher vacuum is usually your friend with infusions.
-david
Discussion Coca-Cola: We're 'closely watching' the market for drinks infused with cannabis . rockyboy2 Life, The Universe, and Politics 10 Oct 17, 2018 01:25 PM
Careful! Caitlyn Jenner Pressured To Date Men For 'I AM CAIT' Ratings Boost? traceyl Life, The Universe, and Politics 10 Apr 19, 2016 08:46 AM
Discussion minimum v for long life for a lipo battery phil alvirez Batteries and Chargers 3 Mar 13, 2016 07:34 AM
Discussion Membrane Tube Infusion (MTI) ??? FoamCrusher Composites Fabrication 14 Oct 18, 2015 05:29 AM
Discussion California Labor Union That Fought for $15 Minimum Wage Now Wants an Exemption kenpoprofessor Life, The Universe, and Politics 8 Oct 03, 2015 07:42 AM
