This thread is privately moderated by RightBrother, who may elect to delete unwanted replies.
Feb 16, 2020, 07:23 PM
Self Balancing Gyroscopic Two Wheeler (Part 3)
I have my gyroscopic two-wheeler vehicle mobile now. It turns left and right though I have not tested sharp turns yet. Need to change the steering linkage a bit and test that out. Usually, gyroscopic two-wheeled vehicles with a single gyroscope will turn well in only one direction and typically fall over in the other direction. I use RC electrics to drive the front wheel and the steering servo. A 550 12volt 18000rpm (no load) motor drives the 360gram gyroscope rotor. Using three 3S 800mah lipos for power, one for the Arduino Uno, one for the gyroscope rotor motor, and one for the RC electrics. Using an LM327 voltage regulator.
Self Balancing Gyroscope Two Wheeler (Part 3) (2 min 30 sec)
Mini-Review NX3 3D Flight Controller Gyroscope Balance For Fixed-wing Aircraft shaul_ei FPV Aircraft 287 Jun 29, 2025 10:48 AM
Discussion PID loop for Two-wheeled Self-balancing bot webdev77 Robotics 1 Mar 23, 2015 09:06 PM
