Feb 15, 2020, 07:03 PM
Ronaldo Nogueira
ronaldopn's Avatar
Question
Multi part motor winding scheme
On the Winding Scheme Calculator, when you add a "/ " to the middle of the winding sequence the result is a two part motor which multiplies the original kV by 2. For example:
AabBCcaABbcCAabBCcaABbcC = x kV
AabBCcaABbcC/AabBCcaABbcC=x*2kV
What happens if you continue adding "/" in the sequence? For example:
AabBCc/aABbcC/AabBCc/aABbcC
Will the kV be multiplied by 4 (4 part motor)?
Ronaldo
Feb 16, 2020, 05:01 AM
Fourdan's Avatar
Hi
I am not sure ..
My first opinion .. :
The Kv value is depending of "serial" or "parallel" organization of windings
So between / / / / / it is (probably) mandatory to have exaclly the same scheme (exactlly low and upper case letters)
For example "ABC/ABC/ABC/ABC" is certainly valid (Kv x 4)
Other opinions ? Christian Lucas ?
Louis
Feb 17, 2020, 07:24 AM
www.speedcroco.de
sorry.
Discussion dLRK Evolution Winding Scheme Skylar Electric Motor Design and Construction 99 Sep 19, 2019 02:54 PM
Question Motor current x winding scheme x termination ronaldopn Electric Motor Design and Construction 10 Oct 22, 2017 06:27 PM
Question Half Parallel dLRK winding scheme ronaldopn Electric Motor Design and Construction 107 Aug 28, 2016 12:49 PM
Question Easy way to run the winding scheme calculator??? leonard3k Electric Motor Design and Construction 158 Aug 06, 2016 05:08 AM
Discussion Motor Winding Scheme MystaMo Power Systems 4 Dec 29, 2010 03:00 AM
