Question
Help On Controling Apex LEDs with FETtec FC
I have the full Steele Apex kit, with the OSD chip and the Regulator board. I have the Apex LEDs wired up to the regulator, and have the provided cable plugged into the FETtec FCs serial 1 port, the OSD and Regulator. Inside the KISS GUI, I have LED set to my knob S1 and LED brightness to knob S2 on my X7S, The AUX channels are definitely correct, and have also tried assigning to a switch. I can't get anything to work to control the LEDs. The LEDs just go back and fourth in red like the Night Rider.
if you wired it up as ImpuleRC says... you control the LED's via the Apex OSD, not via FC...
you can wire up the LED wire from the Regulator to the FC if you want to control it via FC |
Thread Tools | |
Similar Threads | |||||
Discussion | Help - Green flashing LED on FC, won't arm | joe67usmc | Beginner Multirotor Drones | 1 | Aug 03, 2018 07:36 AM |
Question | Need help with leds on 4s quad | BtForest | Beginner Multirotor Drones | 0 | Nov 25, 2015 11:33 PM |
Discussion | Control LED Lights from CC3D FC? Or Direct from RX? | the.ronin | Multirotor Drone Electronics | 6 | Mar 28, 2015 11:03 AM |
Help! | What's this? I need help with a LED controller! | Walter57 | Electric Plane Talk | 3 | Apr 12, 2013 05:06 PM |
Discussion | Need help with Apex MK3 3-cell/Deans setup on Blade CP | Skarn | Batteries and Chargers | 0 | Dec 08, 2006 08:22 PM |
