Feb 14, 2020, 03:18 AM
Kir_Camden's Avatar
Flywing foam cutter
Hello evryone
I prepare my new project of Flywing, probably I named this like The Owl. I don't know but looks like X8
Next step will be cutting by parts and glue it.
Feb 15, 2020, 01:04 PM
Went to mow a meadow
frank48's Avatar
Nice looking wing, are you using templates to manually cut it or a CNC foam cutter?
Feb 15, 2020, 02:49 PM
Kir_Camden's Avatar
Tetris, I mean slice all, step by step. I use 4 axis hot wire technology.
Fast and easy to make some models.
Feb 15, 2020, 03:18 PM
frank48's Avatar
Great stuff!
I'm thinking of building one myself. Can you recommend any software to use?
Frank
Feb 15, 2020, 03:53 PM
Kir_Camden's Avatar
Solidwors, tha best one.
Discussion Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino)! pieri70 CAD/CAM 144 Feb 14, 2020 05:38 AM
Help! Foam cutter plans for cutting vertically also known as a guillotine cutter. JIMA Foamies (Scratchbuilt) 7 Jan 16, 2018 10:14 AM
Discussion How I cut a wing foam core with my CNC foam cutter wzg_zxl The Builders Workshop 21 Nov 27, 2016 02:20 PM
Discussion Hot wire foam cutter problems TarikAgcayazi Foamies (Scratchbuilt) 5 Dec 11, 2015 05:33 PM
Discussion Foam cutter dimmer switch? flybyjohn Composites Fabrication 15 Dec 07, 2015 06:05 PM
