This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Feb 13, 2020, 09:02 PM
old4570's Avatar
LDARC 450x Brushed round two ..
LDARC 450x after rebuild trim flights (6 min 57 sec)
It's round two :
After doing a rebuild on the brushed 450x ...
FS2A micro Rx with inbuilt 5A brushed ESC
8520 motor
1.9g servos ( I think )
Nanotech 260 1s
It flies ...
At first it hunted the ground ..
So I made a larger trim change after many small changes and then it hunted the sky a little .
Ailerons were a little soft - add more rates .
It's very close to where I want it , the rolls were a little slow .
It might tolerate a still larger battery (?) , but it was very decent . ( Just needs to roll a little faster )
Feb 14, 2020, 01:35 AM
eagle60's Avatar
Well done. Still space to improve. I am curios about wich camera you use to make your videos: really not bad at all.
Feb 14, 2020, 03:46 AM
old4570's Avatar
CAM = ELE explorer, one of the budget 4k ones .. ( apparently no longer available = I had a look )
I record @ 2.7k ...
Then edit to 1080 MP4
Elecam Explorer S @ 4K (0 min 31 sec)
Feb 20, 2020, 02:01 PM
eagle60's Avatar
sorry for delay : I have been busy with the kitchen forniture change. Maybe there are still some around, I'll check. How and where do you fix it to shoot ? Seems on a hat.
Feb 20, 2020, 05:09 PM
old4570's Avatar
I have an elastic headband mount , I think you can buy them on Ebay for a few dollars .
You can see the camera gets a little floppy at times if I move too much .
Might be time to maybe upgrade to something less floppy .
Feb 21, 2020, 11:41 AM
eagle60's Avatar
I did find following items :
https://it.aliexpress.com/item/4000385417184.html
https://it.aliexpress.com/item/4000572377884.html
https://it.aliexpress.com/item/32829602142.html
I am just waiting to now if it is possible to change lens because with the one given you can't see very far ( maybe 6 or 8 or 12 mm )
Feb 21, 2020, 06:31 PM
old4570's Avatar
What ever cam you chose (?) , make sure you check out some video samples on youtube . ( as many as you can )
Cams that are really cheap , often turn out to be substandard MJPEG video cams .
Some cams have a zoom function !
Feb 21, 2020, 07:31 PM
eagle60's Avatar
all claim to be 4k, 2 on 16 megapixel, 1 on 12 megapixel, all make video in .MOV format. Anyway good advise, I will follow it.
Feb 21, 2020, 11:50 PM
old4570's Avatar
Check youtube for sample video ..
Generally I go by the $50 rule , decent cams dont cost less than $50 ..
The $50 to $100 price range is where you should be looking , and look at name brands .
Once you find a cam at a price you like with the features you like , check out at least half a dozen reviews / sample video .
If you like what you see and you have minimised the risk of being fooled by Fake claims .
You put your money down .
https://www.youtube.com/results?sear...4k+action+cams
Mini-Review LDARC Tiny 6X vs Eachine QX65 vs Armor 65 Lite - Are brushed Tiny Whoops still fun? SoloProFan Micro Multirotor Drones 27 Feb 03, 2020 06:42 PM
New Product LDARC Tiny Wing 450X 2S 431mm Wingspan EPP FPV Racing Flywing RC Airplane PNP scousethief Geekbuying.com 11 Nov 22, 2019 07:02 AM
New Product LDARC Tiny Wing 450X 2S 431mm Wingspan EPP FPV Racing Flywing RC Airplane PNP GeekBuying Geekbuying.com 2 Jul 30, 2019 03:15 AM
