Feb 13, 2020, 01:32 AM
New Product
The NEW E-flite UMX Turbo Timber BNF Basic...Evolution of a UMX Icon!
See more info below and on the product page via this link:
https://www.horizonhobby.com/umx-tur...n=efl_eflu6950
EVOLUTION OF AN ICON
Scaled down from the legendary Timber® 1.5m, the E-flite® UMX™ Timber was the iconic ultra micro model best-equipped for exciting STOL (Short Take Off and Landing) adventures and beyond…until now. The UMX Turbo Timber updates the original design with a modern turboprop-styled nose and 3-blade propeller, plus a higher-power 3400Kv brushless motor. When using the same 2S 280mAh batteries, this Turbo version provides even better STOL performance with shorter takeoffs and faster climbs. You’ll also enjoy extreme aerobatic capabilities and have the power to hover, then climb out vertically. In the hands of experienced pilots, the UMX Turbo Timber can be flown in more places — even off of water with the optional floats (EFLUA1190, not included) — and in smaller spaces. Plus its high-wing configuration and exclusive optional-use SAFE® Select technology provide plenty of stability to make the UMX Turbo Timber a great choice if you’ve mastered flying at least one model before. This makes it a model that pretty much every pilot, from low-time to long-time experienced alike, should own because everyone will enjoy flying it!
Overview
MORE POWER AND VERSATILITY
At the heart of the iconic UMX™ Timber® model’s evolution into the UMX Turbo Timber® is the addition of a 3400Kv motor and a 3-blade prop. Always known as and still an easy-to-fly, smooth handling, STOL (Short Take Off and Landing) capable airplane, it now has the thrust — with the same 2S 280mAh batteries — to hover and climb out vertically. It can also perform inverted flight, knife edge, snaps, spins and other advanced aerobatic maneuvers with ease. Functional oversized flaps, plus optional-use leading edge slats, offer improved STOL and slow flight performance. Equipped with oversized tundra-style wheels like its predecessor, the UMX Turbo Timber can take off and land on grass and other rough surfaces better than ever before due to the updated landing gear design that secures the fairings to the fuselage. Experienced pilots can fly it indoors in spaces as small as a single basketball court, and almost anyone who’s mastered flying at least one other airplane before can fly it successfully outdoors in large yards, small parks, sports fields, at RC flying fields and many other places. Install the optional floats (EFLUA1190, not included) and you can add large pools, small ponds, and lakes to your flying site options. Included LED landing, navigation and simulated strobe lights add to the fun and make it possible to fly from earlier to even later in the day. Best of all the UMX Turbo Timber arrives 100% factory-assembled — and is ready to fly as soon as you bind the installed Spektrum™ receiver to your compatible transmitter!
More Power
A more powerful 3400Kv motor and 3-blade prop deliver an abundance of power with popular 2S 280mAh batteries, including the thrust to hover and climb out vertically.
Versatile Gear Options
Fly off of surfaces that are impossible for most models of this size to handle: grass, gravel paths, dirt trails, paved surfaces — even pools, ponds and lakes using optional floats (EFLAU1190, sold separately). The updated landing gear has fairings that are secured to the fuselage and oversized, tundra-style wheels to soak up bumps and provide excellent prop clearance.
STOL (Short Take Off and Landing) Capable
The UMX Turbo Timber’s wing is designed with features like drooped wingtips, functional oversized flaps, and to accept optional-use leading edge slats (included) for improved slow flight and STOL performance. These features, along with the lightweight design and high-power brushless motor, make it possible to spring into the air or float down to land in less distance than any other similar class model.
LED Lights
Like the original UMX Timber, the Turbo Timber comes with realistic-looking LED landing, navigation and simulated strobe lights that are factory-installed and powered from the flight battery.
Fully Factory-Assembled
The UMX Turbo Timber arrives 100% factory-assembled and ready to fly right out of the box. It's equipped with industry-leading Spektrum® 2.4GHz technology that binds to your 6+ channel DSMX®/DSM2® equipped transmitter so you can be flying within minutes of opening the box.
Bind-N-Fly® Completion Level Advantage
Already own a Spektrum™ transmitter? Bind-N-Fly (BNF) aircraft make getting into the air quickly and with the best control experience possible easier than ever. They come out of the box with the power system, servos and a Spektrum 2.4GHz receiver installed so all you need to do is bind the receiver to a compatible transmitter, finish any final assembly and fly!
This Bind-N-Fly Basic model is equipped with a Spektrum 2.4GHz DSMX® receiver featuring AS3X® (Artificial Stabilization–3-aXis) technology that works behind the scenes to smooth out the effects of wind and turbulence so you enjoy a sense of stability and precision that makes it feel like you're flying a much larger, expertly tuned aircraft.
If this is your first model of its type, or you want an extra margin of safety while familiarizing yourself with the airplane, you can enable the optional-use SAFE® Select flight envelope protection technology built into the receiver. No programming is required.
With SAFE Select enabled, you get:
Pitch and Bank Angle Limits
• These envelope limits keep the airplane from rolling or pitching upside down. They also prevent excessive climb or dive angles.
Automatic Self-Leveling
• The airplane instantly returns to and holds level flight when the sticks are released and in the center position. It’s also helpful for keeping the wings level during takeoffs/launches and landings.
Easy Switch Assignment—No Complex Programming Required
• The simple procedure for assigning a transmitter switch to turn SAFE Select features on and off doesn't require any complex programming and takes just a few seconds.
Key Features
• Incredible Short Take Off and Landing (STOL) plus sport and aerobatic flight capabilities
• Uniquely capable and versatile so it can be flown in more places and smaller spaces
• More powerful 3400Kv motor for the power to hover and climb out vertically
• Updated turboprop-styled nose, 3-blade prop and trim scheme
• Updated landing gear design to secure fairings to fuselage
• Functional oversized flaps for shorter takeoffs and landings
• Industry-leading Spektrum™ 2.4GHz DSMX® technology
• Easy to fly with optional-use SAFE® Select flight envelope protection
• Unmatched stability and locked-in feel of AS3X® technology for smoother flight performance
• Optional-use leading edge slats for improved STOL and slow flight performance
• Functional and factory-installed LED landing, navigation and strobe lights
• Optional floats (sold separately; EFLUA1190) for flying from water
• Fully factory-assembled and ready to fly right out the box
Specifications
Wingspan: 27.6 in (700 mm)
Length: 19 in (483 mm)
Wing Area: 119 sq in (7.7 sq dm)
Flying Weight: 4.8 oz (124 g)
Motor: (1) 3400Kv Brushless (installed)
Speed Control: (1) Brushless ESC (installed)
Servos: (5) Ultra Micro Linear (installed)
Radio: Full-range 6+ channel Spektrum™ DSMX®/DSM2® Compatible (sold separately)
Receiver: (1) Spektrum™ 6-Channel Receiver
Battery: 2S 7.4V 200–280mAh LiPo with 3-pin JST-PH Connector (sold separately)
Feb 13, 2020, 01:33 AM
E-flite® UMX™ Turbo Timber® BNF® Basic Airplane (3 min 13 sec)
More videos coming later today/next week from:
Pilot Ryan Media: https://www.youtube.com/user/RCAirTrainingCommand
1) First Look/Unboxing
E-flite UMX Turbo Timber First Look Unboxing (7 min 43 sec)
2) Flying
E-flite UMX Turbo Timber, Double Trouble (12 min 55 sec)
The RC Geek: https://www.youtube.com/channel/UC5q...xwMlHf_A-XZGlA
1) Sneak Peak & Initial Flights
UMX Adventures -- E-flite UMX Turbo Timber Sneak Peak & Initial Flights (7 min 45 sec)
The RC Saylors: https://www.youtube.com/user/TheRcSaylors
1) Flying
BRAND NEW RC PLANE - UMX Turbo Timber BNF - TheRcSaylors (13 min 7 sec)
Feb 13, 2020, 01:54 AM
I review RC Products
GBLynden's Avatar
This is not what I was expecting, but I am in!
GB
Feb 13, 2020, 07:34 AM
Fly Low - Hit Hard
Red Flyer's Avatar
I like it too.
RF
Feb 13, 2020, 07:36 AM
FPV IT
TOMZILLA's Avatar
So, larger flaps, 3400kv motor, 3 blade prop and redesigned nose?
Feb 13, 2020, 07:38 AM
The king of mediocre flyin'!
rikybob's Avatar
WHAT?
Money gone!
B
Feb 13, 2020, 08:03 AM
MartinT's Avatar
Looks great!
Are the slats included in the box?
Feb 13, 2020, 08:04 AM
The original UMX Timber already had larger flaps and ailerons relative to the original Timber 1.5m it was scaled from, so we kept them (and the wing overall, less the decals) the same for the UMX Turbo Timber. So the major differences are the nose shape, the 3400Kv motor and 3-blade prop that now deliver unlimited vertical with the same 2S 280mAh batteries, an updated landing gear design that secures the fairings to the fuselage...plus a new control unit that includes the latest chip set to deliver real-time overall battery voltage telemetry to compatible Spektrum AirWare™ equipped transmitters (including the DX6e and 8e, DX6 G2/3 and 8 G2, the DX9, iX12, iX20 and others) while you fly.
Feb 13, 2020, 08:05 AM
Originally Posted by MartinT
Looks great!
Yes, they’re included in the box and still optional to install/use just like the original UMX Timber.
Feb 13, 2020, 08:17 AM
Super, congrats HH !
Feb 13, 2020, 09:34 AM
jobinseattle's Avatar
Been looking for a front yard plane for awhile. This will be perfect and I already have the batteries.
Feb 13, 2020, 09:39 AM
dalecheek1's Avatar
WOW You snuck this right by everyone. HAHAHA.....
Feb 13, 2020, 09:48 AM
30 yrs. Of Aircraft flying!
epoweredrc's Avatar
Finally..... You guys did it,, well I wanted you to do a UMX Timber X but this is close enough this one should 3d well. Preorder placed...
Well another thread i will be very active in.
Feb 13, 2020, 09:52 AM
Parkstormer!
Still loving my original UMX Timber, which goes every session, but it’s clear what the inevitable replacement/upgrade will be. Well done!
Feb 13, 2020, 10:09 AM
epoweredrc's Avatar
Being a mostly 3D guy i never found the umx timber to be enough power. i flew one and after that I was glad i never picked one up. I always like more power. This one should be fun..
Jason or anyone at horizon Hobby can you tell us if the color scheme is painted on or stickers? My umx ultrix i was going to rip off the bottom stickers and they seem to be paint and not stickers.
Can't wait, I have plenty of nano tech 300mah packs ready for this plane.. guess my other umx planes (Beast,habu,f27 wont get flown much after all)
New Product The NEW E-flite TURBO Timber 1.5m BNF Basic/PNP Jason M Electric Plane Talk 1147 Feb 15, 2020 11:31 PM
New Product E-Flite Timber 1.5m BNF Basic/PNP Mattfly Electric Plane Talk 17236 Feb 15, 2020 10:40 PM
Review Horizon Hobby E-flite UMX F-27 Evolution BNF Basic RCGroups Review Jason Cole Micro Ready-to-Fly 23 Apr 24, 2019 12:41 PM
News New Micro! The E-flite UMX Timber BNF Basic Matt Gunn Micro Ready-to-Fly 248 Apr 21, 2019 12:16 PM
News E-flite - Turbo Timber 1.5m BNF Basic with AS3X and SAFE Select (EFL15250) Jim T. Graham Electric Plane Talk 8 Apr 16, 2019 04:16 AM
