Feb 10, 2020, 07:48 PM
RCG Admin
Jason Cole's Avatar
Hitec RDX2 Mini AC Dual Balance Charger
New Dual Charger from Hitec
From Hitec:
Our RDX Battery Charger line offers an array of efficient, sleekly-designed chargers for all discerning hobbyists. The new RDX2 Mini is a two-channel charger, featuring independent circuits which allow the user to charge two batteries simultaneously, regardless of chemistry or capacity. With a powerful, combined 100 watt charging output and 5A current, the RDX2 Mini offers the punch needed to charge 2-4 cell packs at an affordable price. The convenient front-loading design has the balancing and XT60 ports readily accessible for ease of operation at your workshop, flying field or raceway. Additional features include AGM and Cold Charge Modes to safely and easily charge conventional lead-based and absorbed glass mat batteries in cold conditions.
Features:
  • User-Friendly LCD Interface
  • Stores 10 Different Battery Memory Charge/Discharge Profiles
  • AGM and Cold Charge Modes
  • Terminal Voltage Control
  • Built-in Balance Connector
  • Balance, Standard, Fast and Storage Modes for All Lithium Battery Chemistries
  • Re-Peak Charge Mode and Delta-Peak Sensitivity For NiMH/NiCd Batteries
  • Optional Temperature Sensor for NiCd/NiMH Charging
  • Two (2) Built-in XT60 Connectors
  • Smart Ventilation Fan
Charging Specifications:
  • AC Input: 100-240 Volts AC
  • Charge Power: 100 Watts (2x 50 Watts)
  • Charge Current Range: 0.1 5.0 Amps
  • Discharge Power: N/A
  • Current Drain for LiPo Balancing: 300mA per Cell
  • NiCd/NiMH Battery Cell Count: 6 - 8 Cells
  • LiPo/LiHV/LiFe/Lilon Cell Count: 2 - 4 Cells
  • Pb Battery Voltage: 6 - 12 Volts
  • Dimensions: 3.5 x 3.9 x 5.0 in. (90 x 100 x 127mm)
  • Weight: 1.1 lbs. (499g)
The Set Contains:
  • RDX2 Mini Charger
  • AC Cord
  • Two (2) T-Type Connectors
Check out the Hitec RDX2 Mini AC Dual Balance Charger Here
Feb 10, 2020, 09:35 PM
No class, no smarts, and ugly
Looks to be another low watt charger with "100 watt total", so nothing more than two 50w chargers in one.
The selling price will determine if it is even worth it.
Feb 11, 2020, 06:00 AM
Build to fly, fly to fix
I was thinking it, I'm glad you said it...
Feb 11, 2020, 02:48 PM
Bill Glover's Avatar
Cute design (SkyRC T100), but people will buy this "powerful" charger and wonder why it can't charge two 3S or 4S packs at 5A. SkyRC do a 200W version (T200), which would probably have made more sense.
Latest blog entry: Eachine QX65 FPV quad review
Feb 11, 2020, 02:54 PM
I hate charger marketing, always intent on manipulating the masses. Too many do fall for it and as Bill said, see that it does 4S and 5A charging, but it can't do both.
Also
So you can't discharge packs using this? Even slowly this has always seemed like a basic functionality of chargers that it should have. Maybe a typo?
Ill fix it, forgive my rough math
2S charging: 5A
3S charging: 4A
4S charging: 3A
Feb 11, 2020, 03:32 PM
Originally Posted by Darunion
Also
It has a storage mode (which presumably must be able to discharge slowly?), but no specific discharge mode. SkyRC's 200W T200 does have this, although it's restricted to 2A / 10W.
The RDX2 / T100 has a 300 mA balance current, vs 500 mA for the T200. The T200 actually looks like a pretty decent little charger:
https://www.skyrc.com/t200
Perhaps Hitec will sell a version of that at some point.
Feb 11, 2020, 04:00 PM
Ah, thanks for that, i missed the storage mode. Was gonna say, without that mode it pretty much felt useless. It is what I get for skipping to the specs part.
I do agree the T200 is a nice one.
Feb 11, 2020, 04:43 PM
Current Drain for LiPo Balancing: 300mA per Cell aka DISCHARGE current
Feb 11, 2020, 04:45 PM
Weight: 1.1 lbs. (50kg)
You get substantially more charger if you buy the metric version.
Feb 11, 2020, 05:53 PM
Yes - I just ordered one This form factor is great for a workbench charger.
Feb 11, 2020, 08:54 PM
Daemon's Avatar
100W total charge split over two channels, just won't cut it.
FWIW, if you want a really small AC/DC travel charger, it's hard to beat the single
channel HOBBYMATE Speed H6. 200W charge on AC, and 700W on DC, 30W internal
discharge or 700W regenerative discharge.
Only issue I have with it, is a fairly loud fan, but I suppose that's expected with its
tiny 4x2.25x2.5" dimensions.
Feb 11, 2020, 11:21 PM
Hitec is nowhere near the brand they once were. Shame.
Feb 12, 2020, 10:14 AM
Northflier's Avatar
Looks cool, but at 50w per channel its pretty useless for all but the smallest batteries.
Feb 22, 2020, 09:00 PM
Let's be honest in this day and age its useless.
Mar 12, 2020, 12:48 PM
SwampFlier's Avatar
Where can I buy SkyRc products?
iSDT D2 200W 20A AC Dual Channel Output Smart Battery Balance Charger D Gains Batteries and Chargers 53 Dec 07, 2020 01:12 PM
Hitec RDX1 Mini AC Balance Charger Jason Cole Batteries and Chargers 5 Mar 03, 2020 06:02 PM
SkyRC D400 400W AC/DC Dual Charger or Passport Duo 400w Dual AC/DC Touch Charger? ICM Batteries and Chargers 1 May 12, 2018 09:05 AM
Eachine D800 7A 80W Dual Input Power AC/DC Balance Charger【Free testing】 BGjim Batteries and Chargers 94 May 28, 2016 08:31 AM
Eachine D800 7A 80W Dual Input Power AC/DC Balance Charger Danq0 Batteries and Chargers 16 Apr 26, 2016 04:38 AM
