Feb 06, 2020, 08:45 PM
83" KMP B-25 Electric, need help with prop size.
As title states, been putting this plane together over the past couple weeks and am getting to the point of mounting the motors. I am using two G-Force G60 400kv motors. They are likely overkill I know, but I already had one so figured I would try to use them. Based on the weight others have ended up with these planes, I expect weight will be around 16-18 lbs. Based on others, I bought a 14x7 prop (what the LHS had), hooked it up and put my newly acquired wattmeter to it. With a 6s battery it would only pull about 24 amps, and didn't really feel like it had a bunch of thrust. I had wanted to run counter rotating props, but selection is slim. Heck, selection is slim for three-blade props period. I can run a 15" prop, but will only have about 1.5" of ground clearance which I worry might not be enough, heck, 2" with a 14" prop doesn't seem like much either, but I guess I may just have to live with it.
So, opinions on prop size? I tried the motor with a 16x8 3-blade and it pulled about 50 amps. I don't know how hard it pulled because it was mounted in a vise. I found some 15x10 wood three-blade props from china on ebay, I hate to spend $40 each on props, and they also don't have a reverse pitch, so I can't do counter rotating props.
Any help appreciated.
Feb 06, 2020, 10:07 PM
DFS#000178
Rampage's Avatar
To be honest on a trike gear you probably won't even be able to tell the difference with or without counter-rotating props. I run CCW props on my Royal B-25s (and my 60" Twin Otter and my 80" Twin Otter and..) and they fly just fine.
With the 16" 3-blade how many watts were you producing?
At 83" your B-25 is 1/10th scale (rounding up just a hair) so the 15" prop is actually the closest in scale size to the real one. Real B-25 had 12'7" (or 151") so a 1/10th scale prop would be 15.1". So the 15" is the scale size.
It looks like the manufacturer calls for a 16x10x2 on 6s for that motor, so a 15x10x3 would probably work pretty well.
Feb 06, 2020, 11:23 PM
With the 16x8x3 it was over 900 watts at WOT.
I went ahead and ordered two 15x10 3-blades from ZYhobby. $53 shipped for the pair off their website. Hoping for smooth landings and short grass at the field haha.
Feb 06, 2020, 11:26 PM
And I did weigh everything (separately) with two 6s batteries (5000's) it was about 17 lbs. I think it will need lots of weight up front to balance, so I plan on putting both the batteries above the nose gear. Once I get the other motor installed I will be able to better figure out where the batteries need to get the CG right.
Feb 08, 2020, 12:16 PM
Katniss's Avatar
Master Airscrew also makes a 14x9x3. Gives you the 2" ground clearance and better pitch then the 14x7.
A different option would be the Mas 13x12x3.....does come as Cw and ccw versions.
The higher pitch will load the motors up properly.
I do have a 95" ESM me-110 flying on power 60s spinning MAS 16x10x3s. Two 6s 5000 batteries in the nose......combo works really well.
Have a vq p38 with power 60s and the 13x12x3 props....same size as your B25
Feb 23, 2020, 10:38 AM
It is almost ready for a maiden flight. Still waiting on the 15x10 props to show up. Weighs 19lbs 6oz with two 6s 5000mah batteries in the nose. Balances out just a touch in front of where COG is supposed to be.
Discussion Need help with power set up for 83" ESM B-25 DamonH Power Systems 30 Aug 22, 2015 07:50 PM
Discussion Engines for 83" KMP B-25 SRQFlyer Fuel Warbirds 2 Apr 27, 2015 06:14 AM
Help! Need 30-40 inch nitro plane with .25 size engine (can't find one anywhere, HELP!!!) SdpdCadet 3D / Fun Fly Fuel Planes 5 Jan 12, 2012 02:42 PM
Question does a .25 size glow need the same ofsets as a.25 size electric ROCKY2 Beginner Training Area (Fuel) 2 Sep 27, 2010 01:21 PM
