This thread is privately moderated by Eddie P, who may elect to delete unwanted replies.
Feb 21, 2008, 09:52 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 21, 2008, 09:54 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 21, 2008, 09:55 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 22, 2008, 10:16 PM
burkefj's Avatar
X-15 plans
Here are my newer plans for the X-15 showing the simpler construction, and full flying tail.
I've built several versions as rocket gliders, and two as pushers using a purple peril or parkjet motors.
Rocket flight video is here:
Scratch built RC X-15 rocket boosted glider with onboard video (2 min 48 sec)
You can use a motor plate and inset the motor as you would like if using a pusher.
I've flown it on D-12's, E-9's and E-6 composite aerotech reloads, the E-6 is definitely better the boost is good and the burn time is nearly 8 seconds, the D-12 is cheaper and won't go too high, it's a good starter motor. The e-9 is in the middle. Both of the estes motors require you remove the clay cap and ejection and cap the end with epoxy so it won't burn through the forward end.
Plans are here:
https://www.rcgroups.com/forums/show...3&d=1323938163
Build instructions at:
https://www.rcgroups.com/forums/show...4&d=1323938163
flight notes and the rest of the build instructions:
https://www.rcgroups.com/forums/show...5&d=1323938163
build thread:
https://www.rcgroups.com/forums/show...hlight=profile
Tutorial on how to build it with pictures at:
https://www.rcgroups.com/forums/show....php?t=1556299
I recommend a 1/4" 6 foot launch rod to ensure stability especially in windy launches and the E-6RC aerotech reload motor.
If you set at least 1" of movement for aileron and 3/4" for elevator up and down, you should have plenty of throw for compensating for the nose heavy condition, in fact I didn't need as much trim as I expected. I use about 3/16" to 1/4" for post boost up trim.
The plans for the X-15 should show the CG at the wing/fuse interesection and I'm running 3/8" behind this for fully loaded launch condition, which is about neutral when it leaves the rod, burnout CG is about 3/4" ahead of the nominal CG. I would not run the liftoff CG more rearward than this.
Frank
Feb 22, 2008, 10:17 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 22, 2008, 10:19 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 22, 2008, 10:20 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 22, 2008, 10:24 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 26, 2008, 12:58 AM
a.k.a MJ
azamkl's Avatar
Hi everybody. I'm still new to RcGroups.com. Can anyone help me sort the thing out? I'm in dire need of F-18 Flat plan to be built with depron. I like the f-18 as shown on http://laserlizard.com/ but they didn't realease it as FREE plan Is there anyone wanna share the plane for free with me? Thanks in advance..
Feb 28, 2008, 08:24 AM
here are plans for my F-105D 1/13th scale pusher jet design. uses the curved foam method to achieve a more scale look. enjoy!
-beanie
Feb 28, 2008, 03:44 PM
F-18 flat construction
Have you seen these three threads?
https://www.rcgroups.com/forums/showthread.php?t=710361
https://www.rcgroups.com/forums/showthread.php?t=359325
https://www.rcgroups.com/forums/showthread.php?t=808219
Good luck,
LarryR : )
Feb 29, 2008, 02:33 PM
burkefj's Avatar
Deleted Post
Deleted Post
Feb 29, 2008, 02:37 PM
burkefj's Avatar
Deleted Post
Deleted Post
Mar 03, 2008, 02:53 PM
burkefj's Avatar
Deleted Post
Deleted Post
Mar 11, 2008, 11:42 AM
burkefj's Avatar
Deleted Post
Deleted Post
Discussion Please post MINI EDF and pusher jet plans here for easy locating. TerryConners Electric Ducted Fan Jet Talk 57 Mar 11, 2012 10:59 AM
Discussion Firebird pusher jet plans? me_wantee Pusher Prop Jet Models 18 Aug 23, 2008 11:14 AM
Sold MIRAGE IIIC All-Wood Pusher Prop Sport Scale Jet Plans junieb Aircraft - Fuel - Airplanes (FS/W) 0 May 27, 2007 10:19 PM
Sold MIRAGE IIIC All-Wood Pusher Prop Sport Scale Jet Plans junieb Aircraft - Electric - Airplanes (FS/W) 0 May 27, 2007 10:18 PM
Discussion Any great pusher Jet Plans thor4944 Foamies (Kits) 4 Oct 10, 2006 02:07 PM
