Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
OMPHobby T720 with DSM2 Rx ( Maiden )
Chalk and Cheese The difference between using a Taranis Q x7 and the OMP factory transmitter is like night and day ! Fly in stability mode the T720 is snooze town . It is almost boring . I was flying with 100% rates and 50% Expo on the elevator and ailerons . Turning off the stability mode and the T720 flew really nice . On the factory Tx the T720 was a challenge , especially at the slow speed I was flying at and the dead zone on the factory transmitter left you with little to no fine control . On the Taranis it was just gravy . DSM2/x Satellite Rx As mentioned , would bind to the Tx in DSMx , but did not work with the T720 control board . When I tried DSM2_22 everything worked just fine . Zippy 350 .. For this flight I was using the slightly larger heavier Zippy 350 2s .. This be the old blue pack which apparently you can no longer buy . I did order a new yellow Zippy 350 ( larger and heavier again ) . That zippy ( yellow ) 350 just arrived . ![]() The blue one gave some 11.30 minutes of flight time around 50% throttle and when I came home the battery tester reported some 40% battery left . ![]() Kiss my beehive right ? I landed when I did because I was getting worried , I did not really notice any power sag but I was sure I was close to 10 minutes flight time ( over in hind sight ) . T720 Hunts the ground It does ever so gently hunt the ground . I have done a little elevator offset in the Tx , will see if that cures it . If not I may need to re calibrate the gyro . If it did not hunt the ground the ( this one ) T720 would be an amazing trainer on the Taranis Tx . Conclusion A) The factory Tx is junk ( my humble opinion ) B) The zippy 350 seems to have moved the CG enough C) On the Taranis the T720 is so freaky good If I can cure the mild ground hunting , the T720 would be a perfect 10 out of 10 and amazingly Noob friendly . |
Hi, I just discovered your post regarding the OMPHobby T720. Would you mind sharing where did you purchase that DSM2/x Satellite RX? Did you get it thru the manufacturer's site or is it just a normal RX? thanks, Alwin
https://www.ebay.com.au/itm/DSM2-DSM...8AAOSw~hBZ3lfF
THis one I think ! Got it quite some time ago .. Ebay Wont bind DSMx , but did bind DSM2 |
Hi there,
I just got a HobbyMate Satellite RX and got it connected and to bind to my OMPHobby T720 and my Jumper T8SG transmitter in DSM2 protocol. So that work perfectly following your binding instructions in this forum. Now for setup of dual rates an Expo on the transmitter and to assign a 3 way switch what do you recommend? Also does the T720 use channel 5 default for the gyro settings? And the most important , how do you program Sport or Normal modes? Thanks, Alwin |
Reason: more info
Ch5 is for Gyro , best to use a 2 position switch for that .
Rates as needed and expo again to suit you . CG is a little rearward with the OMP , so maybe start with 50% rates on the elevator . Expo might be 50% to start . The T720 is so stable , you may wish to mix in some rudder in full stability mode to get it to turn tighter if needed . Dual rates ? Probably not needed . Stability and less stability ( gyro ) should be enough . |
I used a 3 position switch for the gyro, so I will re-assign channel 5 to a 2-position instead.
Also the 50% Expo on the elevator makes sense. Again, thanks Alwin |
Fly it on the Good Tx ..
Mine is so stable and predictable ( after re calibrating the gyro ) that it is almost boring to fly . I would feel confident handing it over to a Noob after taking it up to say 10 meters and handing the transmitter over . Maybe the perfect buddy box plane ? Also FPV , being so stable ... |
Yes, definitely no more stock TX.
By the way, you mentioned re calibrating the gyro, how do you calibrate this plane with a non-stock or different TX like the T8SG or in your case a Spektrum? I think I tried the same procedure like from the original TX, but it didn't work. |
Hmmm , worked for me with the Taranis ..
If mem serves , stay in Stability mode .. and you then lay the plane flat or maybe , a few deg of nose up - wings level . And pull both sticks bottom left was it .. Keep an eye on the control board doing this .. Hold both sticks while the control board starts flashing quickly . When the control board stops flashing , it is re calibrated and you can let go the gimbals . At least thats the way I did it . |
I think it worked, I used this sequence:
Controller on first, then plane in a level position. Move both joysticks down and out at same time. Rapid flashing for a few seconds and then release. Also I noticed when switch for the gyro is on (offset 100), the red and blue lights on the plane are solid. On Sport mode (switch position off, offset -100), it still has some gyro but more sensitive to controls, the blue light on plane flashes on and off when active. I will test fly again tomorrow and see how it works. Thanks |
Not that I could vouch for ...
I had a Sbus Flysky Rx that just refused to work , I tossed it in the rubbish . Life is too short for stuff that does not work . |
And what is the range you can get with that receiver (i'm assuming it gives more range than the stock receiver - perhaps that is not correct?) i have a jumper t8sg that i want to use to control the plane so i am flexible. sadly the Deviation team are not managing to keep up with the OpenTX team as they have managed to find the protocol that OMPhobby are using and have added it to their latest firmware. regards |
Thread Tools | |
Similar Threads | |||||
New Product | OMPHOBBY T720 4Ch Trainer RC Airplane EPP with Gyro 716mm Wingspan - RTF | tymodel | Parkflyers | 93 | Feb 20, 2021 09:27 PM |
Mini-Review | OMPHobby T720 4-channel gyro-stabilised Trainer RTF | 1auriec | Parkflyers | 59 | Aug 17, 2020 03:01 AM |
Help! | Eachine EX100 DSM2 and Turnigy 9xr pro with orange rx DSM2 not working? | Viusphorna | Australia | 0 | May 02, 2017 06:05 AM |
