Toro 1M DLG in 2-Piece Wing Version
The Toro from Superfly is a nice little 1M DLG and now you can get it with a 2-piece wing to make it the ultimate travel glider.
1M DLG Breaks Down to Tiny Size
The Toro from Superfly is a nice little 1M DLG and now you can get it with a 2-piece wing to make it the ultimate travel glider. It has a Synergy2 wing section and the tails use ht 23, ht22. The cores are made from Rohacell and covered with Carboline carbon cloth. The nose is 2.4 friendly and has a slip on nose cone. All up flying weight will be 130-135g and the trim scheme was designed by Jerem Aero.
There are a variety of colors to choose from and Superfly recommends the X4 Bluebird BMS101 DMG servos. Superfly also offers building services so you can order the kit, RR or RTR version. The kit sells for £259.00.
Check out the 2-piece wing Toro Here
Feb 05, 2020, 11:15 AM
Looks like a Go Mini to me....
Feb 05, 2020, 01:57 PM
Most of them look nearly the same, regardless of wingspan.
What airfoil does the Go Mini have?
Feb 05, 2020, 03:22 PM
From the Armsoar site.... they also have either a 990 or 1m looks like it's gone and out of stock. They do all look the same, Malibu, this, Mini, etc...
Specifications:
Wing airfoil: Proprietary
Wing area: 13.25dm2
Wingspan: 965mm
AUW: 145-155 grams
Feb 05, 2020, 10:52 PM
Team WarpSquad
Brainstorm's Avatar
Thanks for posting this, Jason. I love the idea of a 1m DLG with a two-piece wing, so it’s even easier to transport. Basically means that you could take it on a commercial flight as a “personal item” or carry-on.
Interesting that the Toro weighs 10+ gram less than the Go Mini, despite the two-piece wing. Now I wonder how those two compare to the more recent Deviant.
Feb 06, 2020, 07:29 AM
Wonder if the 2 piece wing works with the one piece wing fuse? If linkage is the same then that would be great.
Feb 06, 2020, 09:51 AM
It works, fuse is same and wings are same outside, just cutted wing and tubes inside🙂
Feb 06, 2020, 01:57 PM
Toaster, not Toast
This looks really cool and so tempting. It would be great to have such a portable DLG for travel. I have a couple of questions:
How is the right wing held in place?
Is the exposed foam likely to get damaged?
What about the tape, if that is used, pulling the skin off the foam?
Are the servos all in the pod?
Is it available for purchase anywhere in the US?
-Topher
Latest blog entry: Evolution Woodie
Feb 06, 2020, 03:12 PM
It's a 4-in-the-pod design, and as far as I know, only Superfly in the UK sells it.
Mar 21, 2020, 09:14 AM
Does anyone know how to contact Kirill (might be not correct name) from Ukraine who is building this plane?
Edit: I might have found him: https://www.rcgroups.com/forums/member.php?u=756925
Mar 21, 2020, 09:28 AM
Yes, that's him. He was responsive to a PM I sent him a few months ago.
Mar 25, 2020, 07:57 PM
The #1 for F3K and DLG
x_Superfly_x's Avatar
We have TORO 2 piece wing in stock ready for shipping, for interest or pre orders please say here.
TORO is exclusive for Superfly and we ship worldwide
Discussion 1m dlg Toro, Hawk, Strike 3 mbrazdil Hand Launch 6 Dec 29, 2019 07:35 PM
Discussion Why are DLGs so expensive, part 3 (and blue servos, V-tails, 2-piece wings, etc.) olgol Hand Launch 250 May 29, 2016 09:43 AM
Discussion Low-wing 1M DLGs xStatiCa Hand Launch 0 Sep 23, 2015 06:23 AM
