Feb 01, 2020, 10:48 AM
Gravity is patient............
CNC foam cutter project
Stumbled across this and thought it might be of some interest here. Looks very simple and very cool.
https://howtomechatronics.com/projec...tting-machine/
Feb 14, 2020, 04:30 AM
Kir_Camden's Avatar
Good project, I found it jsut now.
Feb 14, 2020, 08:54 AM
Retired CAD guy
birdofplay's Avatar
I saw that pop up on the net last week.
Of course I DL'd the files.
BG is currently out of stock on the Heat controller.
The "howtomech" stuff generally has appeared to be a bit "light weight" , sorry.
I was actually more interested in what SW they were going to be using.
The machine parts are easy,
It's the HOW TO USE IT part the is generally the more complicated stumbling block.
Not sure if I want to start another big Project just yet,
since I already have two 3DPrinters and a CNC machine
But, I will be watching.
PS
There are several other similar threads.
This one looks promising as it matured over nearly 5 yrs
Look to the end for the latest mechanical design improvements.
https://www.rcgroups.com/forums/show...-Arduino%29%21
Feb 15, 2020, 01:49 AM
Kir_Camden's Avatar
Wow im not alone here....
Hi nice to see you, i have the same interest for this machine. I use to learn SW for some 3d modeling process.And now I work with 4 axis cnc project machine, hot wire.Its coming evryweek long time parts by parts and step by step....
I call this Foamwire, i try to update all...
Discussion Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino)! pieri70 CAD/CAM 146 Feb 22, 2020 04:30 AM
Build Log CNC Hot wire foam cutter jhraley CAD/CAM 12 Dec 16, 2016 09:38 PM
Discussion How I cut a wing foam core with my CNC foam cutter wzg_zxl The Builders Workshop 21 Nov 27, 2016 02:20 PM
Discussion Cnc foam cutter program info JMDESIGNS CAD/CAM 10 Jan 30, 2016 07:23 AM
CNC foam cutter project Rotozuk Slope 15 Oct 10, 2003 01:09 AM
