Jan 30, 2020, 02:43 PM
Help!
Running light wires in an ARF...
Hi Folks;
Wondering if anyone has any tips or tricks for running LED wires in an ARF...
I have a Twin Otter that I am working on and I want to add a red beacon to the top of the vertical stabilizer. The issue is the fin is covered/finished but its not installed in the plane yet so I have access to the unfinished bottom portion. The vertical stabilizer is a constant 5/8" thick (ply/balsa) and I need to run wires through it (about 14" long). It has some holes in it part way up so its not solid all the way.
Any thoughts, tips, tricks very appreciated!
Cheers;
Eric
Feb 24, 2020, 12:10 PM
You're killin' me Smalls
BrownEyedFool's Avatar
It looks like that is a solid piece of wood, with lightening holes cut in it. If that's the case I don't see you running wires through it, you'd have to drill from the tip to the root and that would compromise the structure too much. Running the wire in the edge of the hinges would likely cause binding. If you can get replacement covering, you could slit the leading edge, very lightly groove the wood underneath to carry the wire, and then patch over it.
Discussion How to run an Endurance Plug-in «Endurance Laser» for Inkscape. GF_Robots Multirotor Drone Talk 0 Jun 20, 2016 05:57 PM
Discussion Bernie should run as an Independant against Hillary and her "fix is in" Democrats Dave Barrow Life, The Universe, and Politics 72 Jun 10, 2016 11:10 PM
Discussion Had an bad crash + run in with public. RcPro97 Crash Discussion 6 Jun 05, 2016 12:05 PM
Help! How to fit the EDF in the nacelle and run its wires Capt. Simon Foamies (Scratchbuilt) 2 May 06, 2016 11:55 PM
Running lights on an E3D... WilliamSettle Sport Planes 7 Dec 12, 2001 05:58 PM
