Jan 26, 2020, 09:03 PM
seadaemon's Avatar
Balance charging
Hello all
I'm fairly new to the drone scene. I am mostly a plane guy. I just got A SG907 drone. Is there a way I can use my balance charger to charge these drone batteries?
Is there some kind of USB adapter ? How do you tell if and when you are at storage voltage ? The drone batteries have 4 lights on them, so to me it is kind of a educated guess as to when they are close to a storage voltage. I disconnect them when the 3rd light is flashing to the 4th light.
Hopefully this makes sense.
Cheers
Sean
Jan 27, 2020, 03:20 AM
Nope, if designed for USB charge, then the battery has a charging controller circuit inside, as is almost every phone battery.
So you have to plug there an USB, which is somewhat equivalent to a smart voltage source, delivering 5V with an embedded current limitation.
Do not connect there a "dumb" 5V supply ! Without a current limit you risk to puff the drone battery.
Jan 27, 2020, 09:31 AM
seadaemon's Avatar
Thank you
So how do you know when you are at a storage charge ?
Do you hook the battery up to the drone and read the app that shows the voltage ? Or do people usually keep the batteries at a full charge which I know is hard on the batteries.
Jan 27, 2020, 03:33 PM
Storage is not a fixed critical value, anything between 40% and 80% is fine.
Your LED method should tell you accurate enough when you are in this interval, imo.
Jan 28, 2020, 12:03 AM
seadaemon's Avatar
Thanks Renatoa
Discussion Fatsharks Balance Charge or not Balance charge The Jackal Batteries and Chargers 16 Jan 27, 2018 04:52 PM
Discussion Balancing charge without balance plug? insistent Batteries and Chargers 17 Sep 03, 2017 05:17 PM
Question Best Charger: Cheap, Charge via Balance Only, Charge via Main Lead Only, 1-6s run Batteries and Chargers 19 Dec 04, 2016 05:41 PM
Discussion Is I possible to over charge a kilo battery while balance charging Droneman314 Batteries and Chargers 8 Jun 18, 2016 11:41 PM
Question How to charge charge Fatshark pack with iCharger 4010 duo with only the balance plug. Turbinetester Batteries and Chargers 9 Apr 08, 2016 02:33 AM
