Jan 25, 2020, 09:57 PM
Help!
Can you identify these retracts
I need to replace the o rings in these retracts. Any idea what they are? They belong to a 94" P-47.
Alternatively, where can I source the rings?
Jan 26, 2020, 12:52 PM
J40
J40
Airplanus Erectus
Hardware store is going to be the most economical. Bring the old ones and your gear. Use some sort of compatible lube/hydraulic oil.
Jan 29, 2020, 02:56 PM
Send lawyers, guns and money
ahrma_581's Avatar
Bearing supply places are also a good place for o-rings and seals, if you have one nearby.
Jan 29, 2020, 04:49 PM
Pro Hoarder
turbonut's Avatar
Are the O rings physically damaged? tears or chunks out of them? if not just soak them in type F trans fluid..most of the time they will get soft in a day or 2
Latest blog entry: In flight
Jan 30, 2020, 06:04 PM
Will regular transmission fluid work?
Jan 30, 2020, 06:36 PM
Pro Hoarder
turbonut's Avatar
Automatic transmission fluid..Most all use something to keep o'rings soft and not leaking..Type F or dexron mercon
Jan 30, 2020, 10:06 PM
J40
J40
Airplanus Erectus
Those look pretty bad in your picture. Could be my eyes.
Jan 31, 2020, 12:18 PM
The one that seals the screw on cap is pretty bad. I placed the cylinder and rod ones in transmission fluid and will try tomorrow to install them and see if
they still leak. The one on the screw on cap should be the easiest to replace, as it does not need to slide...
Feb 12, 2020, 09:49 AM
rabbid fly's Avatar
Just look for a place that rebuilds hydraulic cylinders and hoses, they will have them. If not send them to me in an envelope i can get you a set.
Feb 12, 2020, 10:24 AM
Thanks for the offer. I managed to find some o rings that fit, and so far they are holding pressure all right.
Help! Can anyone identify the Unidentified Object in these photos? skyfridge Life, The Universe, and Politics 104 Nov 11, 2016 02:53 PM
Discussion Can you identify these tail blade grips? 9000rpm 3D Electric Heli Flying 2 Sep 17, 2016 07:19 AM
Discussion Ease help identify these giant retracts JimNM Giant Scale Airplanes 1 May 30, 2016 09:17 PM
Discussion Can anyone help me identify these 2 connectors? nchauvin Multirotor Drone Electronics 0 Mar 29, 2016 10:14 PM
Discussion (yet another one of these)Can you Identify these planes? Endlesslag Fuel Plane Talk 7 Mar 14, 2012 06:06 AM
