This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Jan 24, 2020, 08:04 AM
Video
Test Flight #1 - Eachine Mini Mustang P51D RTF - Elevator Adjustment
Here is a link to the Video:
https://www.youtube.com/watch?v=TiuUcTiVn-A
#GroundControlRC #GlueAndFly #ScratchBuildPlanes #Eachine #MiniMustang #P51D
This Aircraft is courtesy of Banggood!
Eachine Mini Mustang P-51D RTF
https://www.banggood.com/custlink/vvmDAdvdjk
The Elevator on this Plane is just a bit too sensitive in Manual Mode.
I managed to remove the Elevator Control Rod and move it from the Control Horn center hole and relocate it to the Control Horn bottom hole.
This made the Elevator much less sensitive and certainly made it easier to fly in Manual Mode ;-)
I'm pretty happy with this Plane now.
You Can Help Support Us By Using Our Affiliate Link To The Product Below. A small commission (At No Cost To You) helps us buy more items to review.
Spare Parts:
Lipo Battery 1S 360mAh for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/3_7V-360mAh...47791920140372
Brushed Motor 10mm Hollow Cup for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/10mm-Hollow...47791920140372
Prop 130X70mm Propeller Set for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/130X70mm-Pr...47791920140372
Gearbox for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/Gearbox-for...47791920140372
Receiver Board Original 4 CH Onboard Servo for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/Original-4-...47791920140372
Front Landing Gear Set for Eachine Mini Mustang P-51D RC Airplane
https://www.banggood.com/Front-Landi...47791920140372
Eachine Mini Mustang P-51D RC Airplane Push Rod Set
https://www.banggood.com/Eachine-Min...47791920140372
2PCS Eachine Mini Mustang P-51D RC Airplane Spare Part Rudder Angle
https://www.banggood.com/2PCS-Eachin...47791920140372
See you in the Air!
Ground Control RC™ Glue & Fly™ Series Scratch-Build Planes
Consider Supporting Our Channel by becoming a Patron at: https://www.patreon.com/groundcontrolrc
Patrons of the Channel will have access to the latest Aircraft Plans & Exclusive Content!
See Us On Youtube | Patreon | RCGroups
