Mar 25, 2005, 03:29 PM
KidNovak's Avatar
Yippee!
UPDATE: Thanks for setting up my Modified HB, DF Clone.
Here is a update from my previous post of my Jabo II (Hummingbird clone):
https://www.rcgroups.com/forums/showthread.php?t=337354
The project started out to see how far I could take the stock Jabo II 4in1 board without frying it and still perform without any adjustments on the board.
I added a Lipo 7.4v 1200mAh 2cell Lipo battery, GWS EDP-300H motor, Like90 Blades and Head stiffener, DD Tail Kit and 4530 prop with adapter, Aluminum Boom shortened 1 ½”, 4in1 board heat sink on the FET’s, etc…
With a 120 tooth main gear and a 9 tooth main motor gear I get about 15 minutes of flying time per Lipo. Tail motor gets slightly warm, main motor gets warmer, but not hot. Battery is slightly warm after about a 5 minute hover.
There seems to be plenty of power. It takes half throttle (throttle trim all the way down) for a 2 foot hover.
I’m still a beginner so I can’t test the heli to its full potential.
Tail is very responsive and holds pretty well for a cheap 4in1 board. When battery drops below 7.1 volts I have to start using the trim.
I will post a video as soon as I can.
This is the end of this project, my next project will probably be a E-sky Honey Bee CP, then I’ll move on to the big boys.
Thanks again to all.
Novak
Mar 25, 2005, 05:24 PM
Minimole's Avatar
Wow, looks very nice!!!
What make are those packs?
Duane
Mar 26, 2005, 08:18 AM
KidNovak's Avatar
minimole,
These packs are generic, I got 2 batteries and charger from rcbeginners on eBay for $39.
They seem to be OK so far.
Novak
Mar 26, 2005, 11:46 AM
Where did you get that DD mount from ?
Mar 26, 2005, 11:36 PM
KidNovak's Avatar
cheeto,
I purchased the plastic rod end from...
www.mcmaster.com part#:1064K412
I believe the plastic adapter acts as a heat sink with the aluminum boom, because the tail motor is only slightly warm after a 5+ minute hover.
Novak
Mar 27, 2005, 12:02 AM
Awesome exactly what I was looking for
Question List of Tools needed for setting up my work bench sbrv24 Beginner Training Area (Fuel) 12 Aug 29, 2006 08:38 AM
Advise for setting up my dual BL Feigao DF EDF40's LexTalionis Electric Power Systems 1 Oct 26, 2004 03:47 PM
setting up my fan drive-s haldor were are you!!! ESB Electric Ducted Fan Jet Talk 2 Jun 02, 2002 04:25 AM
advice setting up my E-glider JoeR Electric Sailplanes 3 Oct 09, 2001 09:19 AM
Setting up my second Adrenalin, some questions... Erik Johansson High Performance 0 Jul 01, 2001 04:45 PM
