Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
A new bag of fertiliser in the hanger !
The XK A600 = Bag of Fertiliser !
Hmmmm ! Opening the box ! It is light , reasonably made . BUTT and it's a huge BUTT ( Bigger than that ) The Tx is garbage ,, ![]() Moving the sticks you go from no control surface movement to suddenly all the control surface movement ![]() Oh dear ! I had a real bad feeling going to my CG test area ... And that bad feeling was confirmed when I crashed the XK A600 over and over again failing to achieve anything near 10 seconds of flight time . Don't get me wrong , the XK A600 flew just fine in a straight line . But when you wanted to turn it just hunted Terrafirma . This is exactly the same issue as I had with the XK A800 with the factory Tx , only the XK A600 is like 10 times worse . After sufficiently breaking the XK A600 to the point that I was left with no delusions about being able to fly the XK A600 I packed the broken parts into a pocket and headed home . ( Some foam bits were left behind ) .. Conclusion = PITA ( Pain In The Asp ) Pictured is the XK A600 after repairs ... Enter the Dragon ! ( Sorry no , just the Jumper T12 ) Jumper T12 and SFHSS ( Futaba Protocol ) Thankfully the bind process is relatively Painless ! The Rx board has a button on its side .. Just power up the XK A600 and then push the button ( Max ) Now start the bind process in the Tx ( SFHSS ) Multi protocol or Futaba . Thing to remember is = The XK transmitters send out a bind signal on start up .. So every time you want to fly , you need to start by doing a bind .. ( Remember that ) Chalk and Cheese The difference is monumental . With the Jumper T12 I get a hell of a lot more control surface deflection . Also I get nice smooth even surface deflection . Making small fine movements possible , or full deflection if needed . It is like night and day . I have not flown with the T12 yet , especially as there is a Gale blowing again . But when the wind backs off I will be out with the Xk A600 again to see the difference . XK A600 out of the box = Bag of Fertiliser ! XK A600 bound to the T12 = Have to wait and see . |
Thread Tools | |
Similar Threads | |||||
Discussion | New in the bag Jonny Pilot Paraglider Soaring Kit - no prop cage 200$ | Charlescd | RC Paragliders and Kites | 1 | Dec 16, 2017 12:07 PM |
Rave | Wing bags for Hanger 9 Valiant 30 cc | airporter | Giant Scale Airplanes | 3 | Jan 14, 2016 10:13 PM |
