This thread is privately moderated by danielphantom, who may elect to delete unwanted replies.
Jan 21, 2020, 11:48 AM
Trader Rating: 171
Once in a lifetime
danielphantom's Avatar
$1.00 USD
Buyer pays shipping
Sold
CNC airfoil foamcutting service
Hello,
Am available to cut some blue foam cores for you, medium density foam.
I also have pink 25psi foam.
I also have some Epp foam.
I also have some light 1lb white foam for lighter projects.
Send me an email to [email protected] if you have specific questions.
I generally ship priority mail usps with tracking, if its going across the States, it may go parcel select with tracking if the priority gets too expensive.
I can cut off the leading edge/trailing edge and allow for skins if you're into sheeting with balsa/ply and need to add on a sub-leading edge/ailerons--
60" cores generally go for $50 (if two pieces $55)
2M cores generally go for $65 (if two pieces $70)
3M cores generally go for $110 ($5 per additional piece)
Extra big cores > for flying wings etc. go a little bit more since they use up so much foam.
Spar cutouts are available as well slight upcharge.
Thanks for looking,
Dan
Sold Cnc airfoil foamcutting danielphantom Aircraft - Sailplanes (FS/W) 1 Jan 16, 2020 12:02 PM
Sold Cnc airfoil foamcutting danielphantom Aircraft - Sailplanes (FS/W) 4 Jan 03, 2020 04:36 PM
Sold CNC Foamcutting service available danielphantom Aircraft - Sailplanes (FS/W) 5 Mar 21, 2019 10:09 PM
Sold CNC Foamcutting service available danielphantom Aircraft - Sailplanes (FS/W) 6 Mar 02, 2019 02:11 PM
Sold CNC foamcutting service available danielphantom Aircraft - Sailplanes (FS/W) 0 Jan 29, 2019 12:35 PM
