Jan 20, 2020, 10:45 AM
Building a custom wing for a Canard Rotor Wing (School project)
Hi all,
As part of my school project, I am building a Canard Rotor Wing aircraft. The aircraft has a rotor like a helicopter that consists of an elliptical-shaped airfoil. The rotor turns by using a tip jet concept; thrust is provided by an EDF that runs up through the center shaft and to the tips of the rotor blade to push them.
I intend to build it like an airplane wing, with ribs and spars. But I am unsure what the surface of the rotor should be made from. Should I use heat shrink plastic wrap or is it better to make a carbon fiber or glass fiber shell for it? Or perhaps there's another method?
Jan 22, 2020, 09:04 AM
Barney Fife, Vigilante
tom43004's Avatar
You'll probably get a lot of crickets on this one. So if I understand you correctly, you're looking to create hollow rotor blades that allow the exhaust from an EDF to pass through it to the tips?
If so, there's a lot going on here. You'll have the normal bending and torsional stresses that a helicopter blade would see, but then you have the added complexity of a hollow structure and the forces that are imparted by the tip jets.
We might need some drawings to help...
Jan 22, 2020, 03:22 PM
Your going to use a ducted fan to blow air through the rotors like a tip jet? What sort of school are you in with this project?
Do you have any details for your design so we have a little something to work with?
Jan 22, 2020, 07:18 PM
A canard and a powered rotor is a strange combination.
Jan 23, 2020, 06:24 PM
Everything is broken
JimZinVT's Avatar
Can an EDF produce enough pressure to drive a tip-jet rotor?
Jan 23, 2020, 07:49 PM
Id really like to see it!
Jan 23, 2020, 11:48 PM
If it flies, I can crash it.
rocketsled666's Avatar
Yeah, no. That'll never work. The main shaft will have to be huge to pass enough air. If you want a powered rotor, it would be much better to put a small EDF at the end of each blade and use a couple of slip-rings to get power to the rotor (you'll need two at least, and I suspect more to carry the current the EDFs will require).
This type of aircraft is called a "Tip Jet". There have been quite a few sort-of successful attempts over the years. The so-called "cold tip" versions (which is what you're describing) compress the air a *lot* in order to get enough flow at the tip of the rotor. So much so that the air could gets as hot as engine exhaust from being compressed so much.
I was always fond of the Fairey RotoDyne which burned fuel and compressed air in a nozzle at the rotor tips.
An EDF isn't going to be able to develop enough pressure to get the job done.
Help! School Project build help Bodle Scratchbuilt Multirotor Drones 1 Feb 08, 2016 11:24 PM
Discussion need help building a multi rotor (school project) jstnbd0 Scratchbuilt Multirotor Drones 2 Feb 22, 2015 11:57 PM
Discussion High School Multi Rotor Project (For My Students) Buzz_Man Multirotor Drone Talk 23 Dec 04, 2011 06:08 AM
Discussion I want to build a quadcopter for my school project lazer155 Chit Chat 7 Apr 20, 2011 08:28 AM
Yippee! build a fomie from scratch for a school project; Help Needed to Jarg Foamies (Kits) 3 Nov 09, 2004 04:04 PM
