Jan 20, 2020, 07:05 AM
More Speed Indeed!
Hossinarizona's Avatar
Question
Thunder Tiger 46 Pro
I need a carb for a Thunder Tiger 46 Pro. Does anyone have one, or one that will work on it.
Jan 20, 2020, 08:20 AM
A man with too many toys
Perry #1200 will work.
http://www.perrypumps.com/prod01.htm#thunder
Jan 20, 2020, 09:17 AM
Cougar429's Avatar
Can you post your case bore ID? I have one or two Perry standard carbs, (non-pumped) that may adapt.
Jan 20, 2020, 11:33 AM
According to Perry web page it's 0.515".
Jan 20, 2020, 01:22 PM
More Speed Indeed!
Thanks RC Man for helping out!
Jan 20, 2020, 01:25 PM
More Speed Indeed!
Here is the web site (Below) for Perry, as RC Man showed its .515 O.D. Of Carb Neck and, .312 I.D. Of Carb Barrel.
Jan 20, 2020, 04:53 PM
The .40 uses the same carb.
Jan 20, 2020, 06:20 PM
More Speed Indeed!
Greg, thanks for the info, I am still looking for a Thunder Tiger carb.
Worse case, I can order a Perry carb.
Jan 21, 2020, 01:12 AM
I have 4 here in Sydney , Aus . Brand new never used . You can have one but I'm not paying the freight . I change my engines over to a 12mil venturie , same as a Nelson . The carb off the 36Pro also will fit and works quite well too .
Jan 21, 2020, 06:45 AM
More Speed Indeed!
Hi Geoff,
Thanks for the offer, any idea how much shipping would be to Tucson AZ. 85713?
Jan 21, 2020, 07:10 AM
I'll check at the post office tomorrow , send me a pm with your full address and if it's a reasonable cost , I'll post it while I'm there .
Jan 21, 2020, 07:15 AM
More Speed Indeed!
PM sent....
Jan 22, 2020, 07:19 PM
Good carburetors, but they are the old style with straight out needle valve. Absolutely nothing wrong with them, as long as you keep your fingers out of the prop. If you don't get rid of all of them, I'll take one or two.
Jan 23, 2020, 10:52 AM
Cougar429's Avatar
Let me know if you still need me to check the Perry carbs. Work schedule has me chasing my tail.
Jan 23, 2020, 05:40 PM
I found another 4 with angled NVA and whilst they are the same carb , and new , they are from the Pro36 and have a slightly larger spigot than the 46Pro . So would have to be machined to fit in the 46 venturie , not a huge problem as I make venturies for my 46s . I picked them up in a lot of Thunder Tiger and Magnum parts I acquired , hoping there might be some piston / liner /rods in it but only got 2 sets and most of it was for smaller 12-15-25 engines . Mike should have his in the next couple of days , but the post is expensive to your part of the world from mine , like about $ 40 Aus for 2 carbs . For a pensioner here in Aus that's a bit expensive I'm afraid Greg , but up to you !
Discussion OS 46 AXII or Thunder Tiger 46 Pro redrider2 Engines 7 Aug 18, 2013 06:51 PM
running in a Thunder Tiger 46 pro perpetualrepair Engines 16 Oct 06, 2005 03:12 PM
thunder tiger pro 46 pcbang Beginner Training Area (Fuel) 3 Aug 24, 2005 08:27 PM
Thunder Tiger Pro .46 experimental_pil Engines 5 Apr 10, 2005 07:45 PM
How do I take apart a thunder tiger pro .46 firefighter Fuel Plane Talk 4 Mar 26, 2002 03:32 PM
