Jan 19, 2020, 05:02 PM
Mounint Hole Dimensions OS 55 AX vs Royal 45 ABC
Can anyone tell me if the mounting hole dimensions on the OS 55 AX are the same as the Royal 45 ABC?
Jan 19, 2020, 08:28 PM
AMA 46133
SeismicCWave's Avatar
Do you have the Royal 45 on hand? I don't. The 55 AX has a 17.5mm X 44mm hole pattern. I just measured a Thunder Tiger 46 and the 55 is wider for sure. Similarly if the Royal 45 is a clone of the older OS 40 FSR then it will also have a narrower crank case and mounting holes.
Jan 20, 2020, 07:31 PM
I don't have the Royal 45 on hand which is the reason I was asking . I also found the dimensions for the 55 AX but was unable to find the manual for the Royal. I was hoping that someone had a Royal and could measure it to see if it was the same as the OS 55 AX.
Jan 20, 2020, 07:43 PM
AMA 46133
Sorry cannot help there. I no longer have a Royal 45.
Jan 22, 2020, 04:57 AM
AUS 13671
Allan S's Avatar
Hi JB,
I will measure my Royal 45 on the weekend and let you know. There are no dimensions or instructions supplied with motor.
Cheers,
Allan
Jan 22, 2020, 06:59 PM
Royal 45 ABC
Mounting holes - 17.5 x 42 mm
Jan 25, 2020, 03:35 AM
dhal22's Avatar
How old is my royal? 35 years? Probably the first engine I bought from tower. Good memories........
Discussion Mounting Holes for OS 55AX vs Royal 45 ABC JB007 Fuel Plane Talk 0 Jan 19, 2020 04:48 PM
Discussion OS 65 AX vs. OS 75 AX? jptonks Engines 3 Nov 25, 2018 09:49 AM
Discussion ASP S 52A vs ASP XL-52AIIS ABC vs os max 55 gordinir8 Engines 15 Dec 01, 2014 09:37 AM
Discussion thunder tiger pro 61 vs os 55 ax ecfarr Engines 17 Nov 13, 2011 04:58 AM
