Jan 19, 2020, 03:14 PM
GWS F - 15 as a pusher.
I will only be using all the white foam parts of the kit. As a pusher prop job. Couple of questions about the tail surfaces.
1 The plans show a All Flying horizontal stabilizer as 1 way to control it. OR A combination of aileron & elevator surfaces controlling it.............. which for sport ?
The foam parts weigh 14 oz. GWS calls for a GWS brushless 2215 /12 t or a 3008/16 t motor with a 9050 X 3 blade. APC 2 blade is fine.................
I have some good BP H2217-4 3500 kv motors rated at 27amp .... no load amp 1.0 a.... .050 Ohms.... 79 % eff. @ 27 A.....250 watts maximum. Prop to use ?......APC E 5.25 x 4.75....6 volts....20 amps ....16000 rpms.... 13 oz of thrust....75 mph ....All readings are at static. Odd helicopter motors I have around.
High speed vertical is not needed. WOT of 45 should do nicely in windy day to get back to a landing spot.
Thank you.
Jan 19, 2020, 07:41 PM
I should have weighed all the foam pieces out of the plastic bags.
Parts weigh 4.1 OUNCES . & 3.77 S F of wing area.
Now you all know why a 82 year old guy who died legally posts some goofy questions.
Based on the wing loading & LONG body. I am going to use a rubber motor. Why not ? Vertical out of sight launches.
I really do need help !!
I just measured the length I can put in a C F winding tube. 32 " No stress on the foam body that way.
O K Add 1.4 oz for all RC gear. 1 oz for a motor 3/8 oz for a prop. Battery 3 oz. = a 10 oz DF
Gallery scratch build mini F-15 pusher osern Scale Kit/Scratch Built 5 Apr 23, 2017 09:23 PM
Discussion Electric pusher props ? Not as easy as you might think deanmarine Electric Plane Talk 26 Jul 09, 2016 03:22 PM
Discussion GWS F-15 Eagle Pusher Prop version kent1201 Pusher Prop Jet Models 102 Sep 08, 2008 12:02 PM
Combat Models F-18 or F-16, can it be done as an EDF or Pusher electric. Jackspt28 Electric Ducted Fan Jet Talk 3 Mar 07, 2005 07:31 PM
