This thread is privately moderated by Xform, who may elect to delete unwanted replies.
Jan 18, 2020, 10:14 PM
Trader Rating: 4
Micro Heli Flying
Xform's Avatar
$60.00 USD
Seller Pays Shipping
For Sale
Talon 60 ESC with built in 8 amp BEC and Presoldered
Up for sale is a Castle Creations Talon 60 ESC. This ESC was very lightly used. It has seen under 20 light flights and definetely wasn't pushed hard at all. This ESC is a 60 AMP ESC with a built in 8 amp BEC with a 20 amp Peak. Right now, I have it installed in my Trex 470L dominator, but due to being in college and not having enough time to fly, I am selling it and the rest of my Trex 470l. All bullet connectors are presoldered and there is a presoldered EC3 connector. Depending on your setup, this ESC could be plug and play for you. With such a high amp BEC, you will never have to worry about brownouts in the sky from lack of current causing a crash. This is a great ESC.
You will need the Castle link programming cable or the Castle creations field link to program the ESC.
Thank you for checking out my listing and happy buying! Let me know if you have any questions about this item or any other of my items.
The helicopter pictured isn't included in the sale.
Manufacturer Description:
The Talon 60 is well suited for SMALL SCALE OR AEROBATIC HELIS ranging from 360-450 size requiring up to 1400 watts on 6S. This ESC offers Castle’s industry-leading helicopter functions, such as the remarkable direct entry governor mode. Simply type in the desired RPM using a Castle Link USB adapter (redeemable coupon enclosed with purchase) and the free Castle Link Programming Suite running on a Windows ™ PC.
The compact layout and slim profile of the Talon 60 is also perfect for SCALE, SPORT and AEROBATIC PLANES in the .32 - .60 range requiring up to 1400 watts on 6S. Mounting the Talon 60 is simple and stress-free in any setup.
The Talon series ESCs are known for sporting heavy-duty BEC’s designed for today’s servos. The Talon 60 is no exception. With its 20 AMP PEAK POWER and 8 AMPS OF CONTINUOUS POWER, it will keep even the most draining servos at ease.
CASTLE-LINK™
For nearly 20 years Castle engineers have been setting the bar for industry leading software functionality. The Castle Link Programming Suite is the ticket to creating the perfect setup. Gaining access to the host of tuning parameters, including free firmware updates and added feature sets, requires only the Castle Link USB adapter (redeemable coupon enclosed with purchase) and the free Castle Link software on your Windows ™ PC. Users can then fine tune many variables to enhance their level of expertise.
Power System Alerts
The Talon ESCs are programmed to sound a number of tunes and codes using the motor as well as flashing LED patterns to alert users to certain conditions regarding their power system, such as over temperature, excessive load and locked head speed.
Telemetry Capable
Telemetry has the potential not only to improve the safety of our models by monitoring battery voltages, ESC temperature, and other critical parameters, but it also creates other opportunities to get even more fun out of flying because you’ve essentially reduced the risks of “unknown” inevitable crashes. Think of the benefits to be had from alarms that will sound to warn you when there's interference about or if your receiver battery is running unexpectedly low. Requires purchase of Castle Telemetry Link for S.BUS2 (Item # 010-0152-00) and compatible Futaba Radio or Castle Telemetry Link for X-BUS (Item# 010-0148-00) and a compatible Spektrum Radio.
The TALON 60 is PROUDLY DESIGNED, MANUFACTURED AND SUPPORTED IN OLATHE, KANSAS, and is backed by Castle Creations’ 1-year warranty and unparalleled ‘make-it-right’ customer support.
Technical Specs
Input Voltage Range: MIN: 2S LiPo
MAX: 6S LiPo
Max Continuous Amperage at full throttle: 60 amps*
Max Voltage: 25.2V
BEC Voltage: User selectable choice of 6 or 8 volt output (default is 6V).
BEC Output: 20 amp peak** , 8 amp continuous
Size: Width: 1.19" (30.2mm)
Length: 2.56" (65mm)
Depth: 0.41" (10.6mm)
Weight : 2.05 oz. (57 g) with wires
1.09 oz. (g) without wires
Connectors: N/A
Items Needed for Operation: Battery and Motor connectors sold separately.
Tools needed for installation: Soldering iron for attaching High Current bullet connectors to ESC, motor, and battery. (Deans Ultra Plugs, EC5 or Castle Polarized 4mm or 6.5mm)
Application Guidelines: SMALL SCALE OR AEROBATIC HELIS ranging from 360-450 size requiring up to 1400 watts on 6S and SCALE, SPORT and AEROBATIC PLANES in the .32 -. 60 range requiring up to 1400 watts on 6S.
Programmability: Fully programmable Castle feature set using Castle Link USB adapter (coupon for free Castle Link adapter included in package) and freely downloadable Castle Link Windows software. (A small subset of the settings available through Castle Link Windows software can be accessed via manual programming through the transmitter stick.)
Telemetry Link Capable: Yes
Tech Notes: N/A
Sold Castle Creations Talon 25-Amp 25V ESC w/8-Amp BEC, CSE010012800 OilFlyOne Aircraft - Electric - Power Systems (FS/W) 1 Mar 20, 2018 03:54 PM
Sold NIP Genuine Hobbywing FlyFun 80 amp ESC with built in BEC The Don Aircraft - Electric - Power Systems (FS/W) 0 Nov 21, 2013 12:07 AM
Sold 100 amp hobbywing esc with bec built in $55shipped sherlockshah Aircraft - Electric - Power Systems (FS/W) 0 May 10, 2010 04:31 AM
Sold Hifei 60 amp ESC w/ built in 3a BEC - NIP $40 shipped Drew816 Aircraft - Electric - Power Systems (FS/W) 3 Feb 10, 2009 11:18 AM
For Sale Reduced, 60 amp Brushless ESC 2-5S with built in 3 amp switching UBEC, 1 Left The Don Aircraft - Electric - Power Systems (FS/W) 11 Feb 02, 2008 09:32 AM
