Jan 18, 2020, 10:38 AM
ssphoenix's Avatar
Help!
eflite park flyer 480 motor.
I'd like to use this motor since I have it and looks to be perfect power combination for my needs. Problem is i need to find if it can be reversed. The motor will stick out too much out being an outrunner. I wounder if it is possible to reverse the shaft like many other motors do. Meaning i want to motor to be mounted behind the firewall not in front if I didn't explain correctly. Any help would be appreciated.
Jan 18, 2020, 10:56 AM
Sokol
JureZ's Avatar
it can be reversed.
It has a tapered shaft, and you may replace it with one of constant diameter if you wish, when doing the reversal.
OTOH, the radian motor is the reversed version.
Jan 18, 2020, 11:24 AM
ssphoenix's Avatar
Parkflyer eflit 480
Thanks for your reply. If i want to use the exiting shaft, would that work? I see two collars on each end. Is there anything press fit in there? Have never taking one out yet. Much appreciated.
Originally Posted by JureZ
it can be reversed.
Jan 18, 2020, 11:36 AM
Sokol
JureZ's Avatar
the bell is tight fitted to the shaft , and there are also set screws.
I use a wise , a set of socket wrenches as spacer tubes , and a smaller diameter shaft to gently push the shaft out of the bell.
https://www.rcgroups.com/forums/show...89&postcount=1
https://www.maxxprod.com/mpi/tips1.html
https://www.scorpionsystem.com/suppo.../change_shaft/
Question Eflite Park 480 1020kv on 30oz. FW190D J40 Electric Warbirds 4 Apr 26, 2019 05:50 PM
Discussion Eflite park 480 motor in Multiplex Acromaster DucknDive Power Systems 2 Jan 31, 2017 07:24 AM
Discussion Park 480 or Park 480 Rob1962 Power Systems 2 Jun 29, 2016 09:31 PM
Discussion Eflite UMX J-3 Cub as Park Flyer? SanDiegoUteFan Electric Plane Talk 3 Mar 24, 2016 03:24 PM
Discussion something between eflite park 450 890 kv and the eflite park 480 1020 kv Ronald Dobbs Power Systems 9 Mar 14, 2007 08:26 PM
