Esprit Elite Brushless ESCs with Telemetry
Esprit Elite electronic speed controllers (ESCs) will give you an unprecedented level of programming control for your brushless motors. All Esprit Elite ESCs can be used in Airplanes, Sailplanes, EDFs, or Helicopters (Constant RPM).
Esprit Elite ESC
Esprit Elite ESCs can be quickly programmed with the JetiBox, no computer needed. Esprit Elite ESCs have a Data Logging function that lets you check the readings for peak Temperature, Maximum/Minimum Current, Motor RPM and many other parameters that are recorded. This information can be viewed right on the JetiBox after a flight. This allows you to make adjustments immediately and fly again to see the results.
New USB programmability allows you to update the ESC to the latest firmware right from home using Jeti USB Adapter and your PC with Jeti Studio. Fine tuning of your power system has never been easier.
Product Testing: Live Telemetry Data Stream Using Jeti Spin Pro/Mezon & Elite ESCs (1 min 15 sec)
See them all!
Head over to Esprit for pricing and full info!
Jan 18, 2020, 08:50 AM
Not Insane
dogbreath's Avatar
Jetibox? I thought Device Explorer and EX Bus vs EXT interface would be the interface of the future. Will it work with an elite.bin device file and Device Explorer? No mention of governor either for the heli guys. Gov?
thanks
Jan 20, 2020, 05:52 AM
They should integrate the interface with the ESC, it would be nice to plug the esc into a pc and view everything there or view via a phone.
News Esprit Brushless Motors Elite HD Outrunner (1250W - 6250W) Jim T. Graham Electric Plane Talk 9 Jan 30, 2019 08:50 PM
New Product Holybro Tekko32 35A 3-6S Blheli 32 4 In 1 Brushless ESC support Telemetry for FPV Rac jaganfpv Product Announcements 0 Mar 13, 2018 09:15 PM
