This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
Jan 17, 2020, 02:31 AM
Mini-HowTo
URUAV RX PORT - DJI Digital Analog Adapter
This is an adapter to connect an analog diversity module to the DJI Digital FPV goggles outside by cable. Clean solution, but you should install the current DJI update to at least v01.00.02.00 so you get very low latent times up to 20ms. So you don't need any other analog FPV glasses anymore !!
A video module is simply plugged in here and you can fly analog tiny whoops, toothpicks.
URUAV RX PORT 2.0 DJI Digital FPV - https://www.banggood.com/custlink/vvmGbyC4Vi
Video - DJI FPV goggles with analog Module - RX Port (DE) with EN subtitle
DJI FPV Brille mit analog Modul RX Port (3 min 29 sec)
image 1 - delivery with all cables
image 2 - Audio Video IN cable assignment
image 3 - Mounted module on the DJI goggles
image 4 - PIN assignment of the module and the circuit board
image 5 - Eachine Pro58 diversity module - inexpensive and good with the PirX 2.0 firmware that can be installed on the module
image 6 - Rapidfire Module ao the DJI goggles
The analog adapter works very well. If the AV-IN on your DJI goggles stays black, you have to set the image zoom from 100% to 80% under Screen Settings and you can see the AV-IN video. Then it is set to 100% again and the AV-IN video image remains.
FuriousFPV Achilles Diversity Modul
30€ - EU HobbyKing Coupons: FBCKA7LNP , YRCK4JVF8 , YRNLKQ99J - http://bit.ly/HkFurAchil
The good receiver from FuriousFPV with the Achilles firmware with RSSI OSD in the live video. Better than Pro58
Banggood Coupon: aFfBg10 oder Parts8
ImmersionRC RapidFIRE
113€ - $126 - Coupon: BGRapidF - https://www.banggood.com/custlink/vm3v6vafP1
A super fast diversity receiver for the Fatshark Dominator HDO, HD3.
With the new algorithm, you can hardly see the best video with the module without a disturbance.
Hobbyking UK Warehouse Coupon: FBCKA7LNP - http://bit.ly/HkRapidFire
Amazon - https://amzn.to/2ynoKtv
Eachine Pro58 Modul - https://www.banggood.com/custlink/GGvvAsYvDa
The Pro58 Diversity module is still very good and cheap if you install the Achilleas firmware yourself.
But you need a ST-LINK V2 programmer.
The free PirX 2.0 firmware is also very, very good.
DJI Digital FPV System Air Unit DJI Air
https://www.banggood.com/custlink/mGvK0KF1Em
The DJI digital FPV goggles with 1x Air Unit and the remote control. Banggood guarantees duty-free shipping to EU via Priority Direct Mail or EU Priority Line.
iFlight X Titan DC5 6S DJI Air Unit DJI FPV goggles
Coupon: aFfBg10 https://www.banggood.com/custlink/vKvvQCmeSQ
Perfect iFlight X DJI Titan DC5 bundle with the DJI Digital FPV goggles. The freestyle drone is great with BLheli_32 50A ESC's and F7 Dual FC, flies smoothly with RPM filters. I am thrilled with the Titan DC5
The BNF-DJI version can also be used with any external receiver such as FrSky CrossFire. Here only two cables between the Air Unit and FC need to be removed.
$928 - iFlight-RC - http://bit.ly/iFlightTitanDC5DJI
iFlight Titan DC5 6S DJI Digital FPV System -
iFlight Titan DC5 6S DJI Digital FPV System (8 min 11 sec)
Faceplate Head Strap for DJI FPV - https://www.banggood.com/custlink/mKvKBO1hqz
Washable and light-tight strap for the DJI Digital FPV glasses made of Lycra fabric
Lumenier AXII 2 Right-Angle Stubby
https://www.banggood.com/custlink/3DDDgBLA5A
The best right angle AXII 2 stubby antenna for FPV goggles
Lumenier AXII 2 Long Range Straight/Right-Angle 5.8GHz 2.2dBi Gain FPV Antenna
https://www.banggood.com/custlink/Dmvm64jAtf
The best AXII 2 long antenna for long range drones or for FPV goggles
Lumenier AXII 2 Stubby 5.8GHz 2.2dBi Gain FPV Antenna With SMA Connector
https://www.banggood.com/custlink/KmDKgllAWN
Kopterheld Coupons on my Blog, Telegram or FB:
https://kopterheld.tv/
https://t.me/KopterHeld
http://bit.ly/KhFaceBo
My equipment:
DJI Digital FPV System - https://www.banggood.com/custlink/mGvK0KF1Em
Fatshark Dominator HDO2 - https://www.banggood.com/custlink/KmGKeeY4pN
ImmersionRC RapidFIRE - https://www.banggood.com/custlink/vm3v6vafP1
Taranis X9D Plus SE 2019 - https://www.banggood.com/custlink/v3mKeGLLp6
Jumper 4IN1 Multimodul - https://www.banggood.com/custlink/vGvGNp7s07
FrSky R-XSR - https://www.banggood.com/custlink/DGvDgKOu8B
CADDX Ratel - https://www.banggood.com/custlink/KKKm6mLf9Q
Youtube – https://www.youtube.com/kopterheld
FB – http://bit.ly/KhFaceBo
Blog – https://kopterheld.tv/
RCGroups – https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Dec 06, 2020, 12:19 AM
uLight.Me
ulightme's Avatar
can you tell me if this pinout is the same on both ends of the cable?
Question Analog vs Digital Servo Compatibility glhj123 Electric Power Systems 2 Jul 04, 2016 05:31 PM
Discussion Digital with analog servo kid at 55 Servos 7 Jun 25, 2016 07:17 AM
Question Switching servo guts:digital HKSCM9 board into tgy9025mg (analog servo) interestingfello Servos 0 Apr 20, 2016 07:06 PM
Discussion Analog Pilot trying to go Digital rsiaviation Mini Helis 5 Apr 16, 2016 09:58 AM
Discussion Analog to Digital - Help me hack my kid's toy LeeRoy Radios 5 Dec 31, 2015 03:11 PM
