Foxtech - Argus V2 3D Modeling Oblique Camera
Argus V2 3D Modeling Oblique Camera is an ultra-light, small size oblique camera that takes 120 mega pixels (5x24 mega pixels) high-resolution photos.
Its quick-mount design makes it easy to mount on a variety of fixed wings and multirotors like Baby Shark VTOL, Rhea 160 Hexacopter, Gaia 160S, the combo of which provides users with the best and cost-effective 3D mapping solutions. Argus V2 system adopts advanced shutter synchronous full drive technology. It can synchronize five-camera signals and trigger shutter once detecting flight control trigger signal, hence thoroughly solving the problem of photo loss and omission. And the minimum photo-taking interval is only 0.8s. It is equipped with an active cooling system, consisting of an internal fan, which can actively start cooling in a high-temperature environment and ensure that the equipment works stably for a long time. Argus V2 takes photos of full color, low distortion, and higher sharpness, for each lens is manufactured with its calibration parameters to facilitate later higher precision image correction. It has built-in IMU/POS that records and exports GPS coordinates and attitude angle at the exposure moment, which can be transferred through a USB cable. And also it can realize real-time positioning by means of three-redundancy attitude (pitch, roll, and yaw)GPS recorder. Equipped with a unified built-in storage module, it only needs a USB cable to connect with the computer, which allows it to achieve high-speed and stable data access, hence avoiding the problem of inefficient data copy or loss caused by frequent replacement of memory cards or storage card slot.
Photos
Note: Foxtech Argus V2 will be shipped 7 days later after the order is made, please contact customer service staff for specific delivery date.
Specifications:
  • Dimensions: 145x165x100mm
  • Weight: 680g
  • Number of lens: 5 pcs
  • CMOS size: 23.5-15.6mm
  • Data Port: USB 3.0
  • Storage Capacity: 320GB(customizable)
  • Minimum photo interval: 0.8s
  • Built-in IMU: Support
  • Built-in POS: Support
  • Installation angle: 0x1 & 45x4
  • Pixels: 5*24 mega pixels, total pixels 120 mega
  • Voltage: 12-26V DC
  • Max Power Supply: 25w
  • Power supply type: Standalone battery or Airborne power supply
  • Lens group configuration: 25-35mm
  • Real-time positioning accuracy: Centimeter level
Learn More
Head over to Foxtech for more info and pricing!
New Product Foxtech HoryzonHD V4 1080P FPV camera- revolutionary HD camera!!! glassfox FPV Equipment 387 May 25, 2019 05:54 AM
Article 3D FPV - Skyzone 3D Goggles - Foxtech Jim T. Graham FPV Equipment 23 May 31, 2017 08:22 PM
Discussion Foxtech Foxtech motor W50-08 kv330 V2 specifications TurboJoeJT Foxtech Hobby 2 Apr 11, 2014 09:58 PM
Discussion What's most effective for a fixed camera position, vert or oblique? Fairmont Aerial Photography 1 Apr 12, 2008 11:51 PM
