Prop Saver 0 Ring Sizes, Prop Saver idea link
pick these up at your local HD in the plumbing dept, 24cents each.
#13, 7/8 x 11/16 x 3/32-stk no 35730B for IPS motor assy. #14, 15/16 x 3/4 x 3/32-stk no 35731B EPS 300-350 Brushed #15, 1 x 3/4 x 1/8 -stk no 35732B EPS/geared with Brushless 370-400 #15 is less apt to pop off your prop saver in High thrust applications, but it is a PITB to stretch over the prop savers wing nut ears. Hope this helps, Doug Prop Saver Idea Previously posted https://www.rcgroups.com/forums/showthread.php?t=291939 |
I've started using slices out of 3/8" surgical tubing. I picked it up at Sears Hardware. Using 2 slices ~1/4" wide, I'm running ~18oz of thrust (100 watts) on one of my 3D planes. I use ~3/16" wide for the smaller 10oz thrust motors (70 watts)... cheap, about $3 for 10' or so!
ARGH!!!!!!!! Gave UP on expensive O-rings LONG ago .... Rubber bands work , cheap , colorful , easy to use ...... mostly CHEAP !!!!!! hahahaha we use servo arms (large servos ) for the propsaver
Latest blog entry: Lost plans
surgical tubing here...works great. i have about 35 flights on one saver and stillhave yet to replace the tubing
Doug:
I use # 13 on the Pogo for when I land it on the wrong end
I just happen to have 600 feet of surgical tubing now just for prop savers
![]() Gene you got a great price on that! What do yall think is a good price per foot? Of course I went to 'Lowes' hardware today and paid $1.40 per foot then found the box of 600 feet on my doorstep when I got back lol. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Discussion | Which o-ring for custom CDR prop saver? | caseym | Electric Power Systems | 13 | May 24, 2007 05:43 PM |
| Where to Order Prop Saver O-Ring | varmato | Electric Power Systems | 15 | Dec 05, 2005 07:45 AM | |
| AXI prop saver idea | power | Electric Power Systems | 7 | Mar 26, 2004 07:32 AM | |
| Question | Prop Saver | tim_j-rome | Parkflyers | 4 | Dec 13, 2001 09:49 AM |
| GWS prop saver | Der Zip | Parkflyers | 2 | Jun 01, 2001 10:03 AM | |
