Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
VD5M FrSky 5ch receiver ( Micro )
I have had this receiver on hand for ? Almost 2 years maybe and never got around to using it . ![]() With my recent interest in Micro Su-27's , I thought it might be time to blow the dust off this Micro Rx and give it a go . I have some small servos , and I have some 1s ESC's .. And I have some small brushless motors that are 1s capable if not 1s .. ![]() Anyhow .. I have not seen much info on this Rx ... Ch2 and Ch5 = D8 ... Use the bind plug to connect .. I put power into Ch3 The Rx will go into bind mode when power is added ... Have your Tx in bind mode or put it into bind mode .. For me the bind was so fast I never saw it .. I removed the bind plug and added a micro servo and it looks to work just fine .. Power is VIA a 1s ESC ... This Rx apparently can do V8 mode ( Ch1 and Ch5 ) , but I could not get a bind .. Maybe some frequency offset ? Anyhow , will probably use this Rx for my next Micro Su-27 build . It will give me more aileron ! ( Than the F949 board ) Now , what motor to use ? |
Thread Tools | |
Similar Threads | |||||
Discussion | OpenSky - Opensource FrSky compatible firmware for CC2510 based receivers (VD5M) | fishpepper | DIY Electronics | 31 | Sep 07, 2016 03:25 PM |
Help! | frsky vd5m very erratic behavior?! | zoohr | Radios | 4 | Dec 02, 2013 01:57 AM |
Discussion | regular connectos on frsky VD5m, any issue? | P.I.Engineer | Radios | 2 | Jan 19, 2013 03:10 AM |
Discussion | Frsky VD5M in walkera? | Hexperience | Micro Helis | 0 | Sep 03, 2012 09:34 PM |
