Hobbyking 540W PSU problem
Hello,
I recently got an older Hobbyking 540W PSU and noticed when I start to charge my 4S 6750mah lipo packs, PSU starts clicking. This clicking noise stops after 10 to 20 seconds. If I want to charge another 4S 6750mah lipo pack on the second channel, PSU starts to click again and goes to OC mode. When I charge with 7A it clicks but if i lower the current it clicks less and I can charge second pack with no problem. After the clicking stops, I can charge with higher current without a problem (up to 240 watt per channel). However this doesn't happen if I charge smaller lipo packs (2S xxxx mah) which means less watts consumption. I'm using Icharger 4010 duo. Here is the video (turn on the sound) |
So what is the question? You're stressing the PSU.
Put a wattmeter in between and measure actual voltage, amps & watts drawn. Then you'll want to stay at about 80% below where it starts clicking. Or replace with a more powerful unit, maybe higher voltage too depending on what you need. I believe that charger is pretty sensitive to input, reduced longevity if it isn't pure & steady. It will want ~36V to get max power (2200W), usually 48V PSUs are reasonably priced ex-telecom, but try to get an adjustable one, to go a bit lower. |
If I'm charging with 120 watt per channel and PSU is 540watt it's less than 50% of total PSU power.
The problem I see is when the charger starts charging. If I set 4S lipo pack and 7A charging current it clicks but if I set 4S, 3A it doesn't although the charger never starts charging with full power. It's starts below 1A current and slowly rises. It's like if the charger checks if it has the full power capability at the beginning. Is that possible? My friend has Efuel 540W PSU and it doen't have this problem. Is it possible that the built quality is better or do I have some damaged elements in my PSU? |
I also plugged it in my Kipor 2600 generator and it's the same problem. I see the input voltage on charger. When it starts charging the voltage drops from 18V to 17,7V and than slowly rises back. |
Likely the voltage isn't stable enough and the input meter on the charger isn't fast enough. Even a cheap meter would be much faster. I do agree with what John said, a wattmeter would be a good measurement.
I would bet that the voltage is not stable enough under load and the charger obviously doesnt like that. I would aim toward replacing your power supply, especially since as you said you connected a differetn supply and it worked fine. A faulty powers upply could damage a charger, and that is a nice charger that isnt worth risking it. |
Otherweis I'm using HP DPS-800 GB A 1000watt PSU which sometimes shuts down when the charger starts charging. I read on this forum that this PSU needs a lot of load to work properly. I will try to measure the voltage with a meter. Thank you Darunion and John61CT for all the info. |
Quality brand new ones at high voltage & power are very pricey, more than the charger. Yes even Mean Well.
But top notch ex- server room or telecom PSUs are cheap as chips, e.g. https://www.ebay.com/itm/TECTROL-150...3/301284483957 https://www.scribd.com/document/371935359/TCP1U-1200 |
There are two possibilities causing this clicking.
One is that the psu is going into an overload mode known as “hiccup mode”which is used in switch mode psus because you cannot reduce the duty cycle far enough at short circuit. The frequency of the clicking sounds faster than I would expect, so I think it is more likely that the control loop is not properly compensated and is therefore running in a squegging oscillation. Either way the psu should be returned as faulty. Wayne |
Thread Tools | |
Similar Threads | |||||
HobbyKing 540w 100~120v Power Supply (13.8v~18v - 30amp), Burned! | whobby | Batteries and Chargers | 4 | Oct 03, 2018 07:59 PM | |
HobbyKing 540W 30A PSU & Mod | Mad_angler1 | Batteries and Chargers | 15 | Sep 22, 2015 06:52 PM | |
Hobbyking 540w PSU outputs 34volts | barker01 | Batteries and Chargers | 0 | Dec 20, 2014 08:36 AM | |
Hobbyking 540W PSU - Upgraded Cooling Fans | IntegrityHndywrk | Batteries and Chargers | 0 | Oct 11, 2013 11:42 PM |
