Jan 10, 2020, 08:57 AM
→ 404 Not Found
Justapoke's Avatar
Whoops!
iFlight BumbleBee 3 Inch 6S HD CineWhoop w/DJI Caddx
What if you take our popular MegaBee frame and optimize it in every detail? You get the BumbleBee!
The BumbleBee HD Quad BNF features the amazing new DJI FPV system, this quad makes flying FPV truly breathtaking. With the 720p 120fps video in your Goggles, DJI has set the bar at a new high for clarity and image quality in FPV experience.
The whole was frame reduced to a mini mum size, mini mum weight, achieved a 140mm diagonal motor distance and even fit the DJI Ai r Unit inside.
We've also added a new bumper approach in cooperation with Laurent Athenol (Frame-Concept).
Small space? Tight gaps? Indoor safety? But you need that 4K? Well, here goes your for GoPro!
There's always that customer that has this indoor project but just want to get footage in 4K. Here's the BNF you need to get the job done!
You have this location you wanna fly in, but no way you'd fly your standard razor blad es around you or your friends?
Do you just love the style and the fact that "props just won't break that often"? ... GO FOR IT!
More info: DJI Digital FPV version
Caddx Ratel version
BumbleBee BNF Specifications:
- SucceX-E mini F4 FC
- SucceX Mini 40A BLHeli32 ESC
- Motor: XING 1507 2800KV 6S
- Wheelbase: 142mm
- Bottom plate thickness: 2mm
- Top plate thickness: 2mm
- Top and bottom plate spacing: 25mm (aluminum column height 25mm)
- Propeller size: 3 inch
- FC pattern: 20*20mm, 30.5*30.5mm
- FPV cam spacing: 19mm
- Weight: 332g (without battery)
Features
- No Props or frame in view!
- Bumper prop guards to protect the sensitive environment or yourself
- High performance True-AIO Board SucceX-A (F4 FC + 40A BLHeli32 ESC) to safe weight and space
- DJI FPV Ai r Unit 720p 120fps FPV feed (recor d in 1080p/60fps)
- Full 3K Carbon Fiber ai rframe + protective TPU
- Butter smooth XING1507 2800KV motors
- Pre-tuned with smooth freestyle settings
BumbleBee HD Quad BNF Included Components and Parts
- 1 x BumbleBee HD Frame
- 1 x DJI Digital HD FPV Ai r Unit (FPV Camera + Ai r Unit Module)
- 1 x TPU Bracket for DJI Ai r Unit Module
- 1 x TPU Antenna holder for DJI antenna
- 2 x TPU camera side plate soft mount
- 2 x 3045 3-blade prop (Set of 4 - Color May Vary)
- 2 x DJI FPV Ai r Unit Antenna (MMCX 90 - Pai r) (From Ai r Unit Packaging)
- 1 x iFlight Lipo Strap
Camera mount for Gopro is not included.
Camera Mount for Gopro Hero 5/6/7/8, click here.
Additional Suggested Parts
*DJI HD FPV Goggles
*Radio Controller
*DJI Remote Controller (Mode 2)
*Battery (light indoor 6S 850mAh / more flight time outdoor 6S 1300mAh)
Important
The DJI Remote Controller is recommended for beginners since you won't need to set up another receiver, but it is also optional in this BNF drone because it is NOT required in order to use the FPV system. If you don't choose to use the DJI Remote Controller, you can choose a receiver option for your transmitter and then bind to your own radio as usual.
Caddx Ratel version
P.s. also check the DIATONE MXC TAYCAN: https://www.rcgroups.com/forums/show...w-Runcam-Nano2
Jan 10, 2020, 09:07 AM
→ 404 Not Found
Justapoke's Avatar
Caddx Ratel version images:
Jan 10, 2020, 09:24 AM
→ 404 Not Found
Justapoke's Avatar
BEST CINEWHOOP of THEM ALL? - iFlight Bumblebee - FULL Review & Flights (13 min 25 sec)
Jan 10, 2020, 09:50 PM
Which is the better of these two? The Diatone Taycan or iFlight Bumblebee?
Jan 11, 2020, 02:26 AM
→ 404 Not Found
Justapoke's Avatar
Hard to say as they are just out. They look very simular.
Time will tell, they are probably both good as both iFlight and Diatone usually seem to know what they are doing.
New Product iFlight MegaBee 3 Inch Cinewhoop MultirotorDrones Mini Multirotor Drones 2 May 09, 2019 07:49 PM
