Lee Ulinger Designed Yak-55 Build thread
I pick up a Lee Ulinger Designed Foamtana at the Arizona Electric Festival a few months back and to say it’s a great flying plane is an understatement. Word has it that his Yak55 flies as good as the Foamtana so I picked one up. This plane is about the same size as the Foamtana and should weigh about the same.
Lee Ulinger Designed Yak-55 Wing Span: 39in Wing Area: 394sq. in. Length: 39in Weight: 16oz Available at: http://www.darrolcady.com Equipment to be used: Servos: 4 Hitec HS-56 Motor: Hacker A20-22L Outrunner Controller: Hacker X-20 Battery: ThunderPower 3S-1320 Propeller: 10x3.8 APC-Slow The plane arrived well packaged in a single small box with the peaces bagged and taped to the inside of the box. |
Laying out all the peaces, everything is very strait with clean cut lines.
The Assembly starts with gluing the carbon rods into the wing and elevator. I used 30 minute epoxy by poring it into the slot and then pressing the rod in place.
Wipe away any excess glue then cover with plan protector and weight down until dry.
The fuse construction starts by gluing on the cross brace. The braces slide into cuts in the fuse making alignment simple. Just use a triangle to check everything is at 90 degrees and run a bead of foam safe CA down both sides. You also add the rear tri stock at this point.
For the opposite side you need to hang the fuse off the side of your work table and repeat the above step.
With the cross braces in place glue the motor mount and weight down until dry.
Then sand motor mount supports to fit behind the mount and glue in place.
Time to finish the wing by taping the ailerons on. Make sure you tape the top and the bottom. I use the recommended Blenderm medical tape.
The last step for the wing is to glue the wing centerpiece in place. There is a mark to help line things up just right.
Finished wing ready to be glued to the fuse.
Slide the wing in place and check alignment. When you are happy with the placement run a bead of foam safe CA around all connecting seems.
After hinging the elevator onto the stab the same way as the ailerons slide the stab into position an check alignment. When satisfied glue in place with foam safe CA.
With the stab in place tape the Rudder on.
The last step before installing your radio gear is gluing in the control arms. Cut a slit into the ailerons so that the control arms hole will be directly over the hinge line.
Thread Tools | |
Similar Threads | |||||
Build Log | Hyperion Yak 55 25e Build,tips, And Flying Thread | hemituda | 3D Flying | 214 | Jun 19, 2018 11:33 PM |
Great Planes Yak 55 Build Thread | ToyRunner | 3D Flying | 90 | Jul 10, 2010 07:12 AM | |
Discussion | Aeroworks 100cc Yak QB Build thread... | Joe__Hunt | Fuel Plane Talk | 8 | Dec 24, 2006 10:13 PM |
Insane Foamies Full Fuse Yak-54 build and fly thread! | j_z_123 | 3D Flying | 52 | Aug 20, 2005 09:48 PM | |
Twin Vasa 55 Typhoon.....Build thread | Robert May | Electric Ducted Fan Jet Talk | 27 | May 04, 2005 05:40 AM |
