Best DJI FPV Goggle Power Cable Holder
It's well known that the DJI FPV Goggles power cable is a loose fit and is easily pulled out. Here's an easy fix.
Simple, Elegant Cable Holder
It's well known that the DJI FPV Goggles power cable is a loose fit and is easily pulled out. That's not good, especially when you are flying. I've seen various ways of mitigating that issue, like using zip ties, but that doesn't look good and with a high end system like this, esthetics do matter.
That's where Thingiverse user FedorCommander comes to the rescue with this simple, yet elegant and good looking power cable holder. It's small, attaches to the google strap mount and blends in perfectly like it was done on purpose. It holds the power cable perfectly and prevents it from being pulled out by the battery or any movement on the cable. If you have a 3D printer, you need to make this part or have one of the many online printer services make it for you.
Check out the Cable Holder on Thingiverse
Jan 08, 2020, 10:01 AM
RobDog's Avatar
Thank you for providing the link to this. I've yet to use my goggles yet, but can see it being an issue.
Jan 08, 2020, 10:10 AM
RCG Admin
Jason Cole's Avatar
No problem. I made one for my set and it works great and I don't have to worry about it cutting out mid flight. I would certainly do something, even it it's just zip ties.
Jan 09, 2020, 07:30 PM
Too bad I don't own a 3D printer. I must be too far behind the times, lol...
Jan 23, 2020, 02:08 AM
FedorComander's Avatar
Wow... Found it by accident thanks for posting mate!
Feb 05, 2020, 01:19 AM
need to ,thanks!
Discussion How to Enable DJI FPV Goggles’ 1000/1200 mW High Power Mode BoostFPV FPV Talk 44 Apr 02, 2020 10:31 AM
Help! Which fpv goggles are best for DJI phantom 3 pro dsw1113 FPV Equipment 2 Jan 04, 2017 08:33 PM
Discussion Best way to power FPV goggles: Stepped up USB battery pack P.I.Engineer FPV Equipment 1 Oct 16, 2016 03:30 PM
Help! Best flight simulator cable for FPV Freerider? Conman77 Simulators 0 Jul 01, 2016 01:51 PM
Poll The Best FPV Video Goggle bosco49 FPV Equipment 4 Jan 23, 2016 03:44 PM
